Raro wrote:It's funny that they don't come prepared for the QLK, well maybe some more modern ones are, I have to check if mine is also like that even though it's older.
crypmanii wrote:I don't believe that the QLK bracket for the bottom of a Permobil F3 fits into holes already on the bottom of the chair. The guy that I have work on my van and set all that up says that it requires him to drill new holes in the bottom of the chair. I would like to just see a picture of an F3 with the bracket already attached so I can get an idea of it's exact position and what kind of ground clearance will be remaining.
slomobile wrote:Rover,
Does the QLK attach to the 5 small holes in the middle, the 2 large holes closer to the sides, or some other existing holes? The QLK link I found doesn't show the chair side at all or describe it.
Is there maybe a specific part number that should be used on permobil but people are using a universal part instead that doesn't fit as well? I've also heard from QLK dealer (United Access) that it requires drilling holes in the F3. I believe you over them, I'm just curious how that info gets spread.
anttttttt wrote:Isn’t the stabilizer mechanism different between ez lock and qlk? Or do you not have one and just use the bolt? I know they recommend/require it for driving from your chair
)Return to Everything Powerchair
Users browsing this forum: No registered users and 299 guests
