3. If a battery is healthy, like your MK batteries? and it is DISCCONNECTED electrically from the chair, by removal, or use of the breaker, or by disconnecting a battery connection physically then charge it (them) with a 12V charger seperately every 2 to 3 months.
Burgerman wrote:Is there anything else connected to these batteries? Such as a USB power system or anything? I suspect you actually left the chair turned on. And it discharged the battery to a low figure. And the natural self discharge on an old set of batteries did the rest. But theres is no way to know unless you MEASURE THE CURRENT while turned OFF.
But lets say I did let the chair on, Isn't the chair auto shuting down after x time or more importantly when the batteries go too low for the chair (lets say between 20v and 23v, ) is not the chair shutting down the same way if the batteries are too low a chair won't start?
I have no idea what is in that box with a switch.
emilevirus wrote:I mean, they only have 0.5W LEDs. It would take ages to discharge a battery. You'd notice before it took 1Ah out of the battery.
emilevirus wrote:Why did you say it uses Pilot+. If it's a 2014 there's no way it's Pilot+. It must be R-Net. There must be a switch box somewhere for lights. Usually velcro'd near the joystick. Or it's been removed. That switch NEVER works. I don't know what switch they use but it needs to be replaced every 2 months.
