by Burgerman » 19 May 2010, 16:02
They are not battery terminals!
They are cable ends, or ring terminals.
They should be a snug fit on the cable. Depends what size cable you have.
Then soldered with care! If your cable is 10 sq mm then get the matching size.
The people selling them on ebay usually have a variety of sizes. And a description of how they relate to the "code" when ordering. Get some heat shrink tube too to keep it all tidy.
This relates to some bigger ones but you get the idea! You want 8mm bolt hole and 10sq mm cable. Which means you would order 10 -8 ones. Get a huge bag! To practice...
Quote from a seller:
You are buying FOUR battery eyelet connectors suitable for connecting a 25mm sq section battery cable (the cable entry hole size in the connector is approx 7.00 mm dia.) to a stud mounting. We offer this terminal in the following sizes 25-6, 25 -8, 25 -10, 25 -12. The number AFTER the dash indicates the size of stud the connector is designed to fit to, i.e. 25 -10 will connect a 25mm sq battery cable to a 10mm (M10) stud. The connectors can either be crimped (using specialist tools) or soldered onto the cable.
All the 25-? variants are the same price, please advise by way of eBay messenger what size of stud hole you require.
We offer all sizes of this popular connector from 6mm sq cable up to 240mm sq cable fittings! We don't list all available sizes but should you wish to purchase other sizes please advise us and we will list the required size and quantity.
