Page 1 of 2
Hyperion Bluetooth - EOS0615iduo3+ and 720i super duo 3
Posted:
21 Jan 2012, 07:17
by andyp
Hi
Hyperions latest 5.5 firmware is bluetooth enabled.
Anyone have any ideas how to connect a serial bluetooth module to the Hyperion EOS0615i duo3+ and EOS720i super duo 3?
Andrew
Re: Hyperion Bluetooth - EOS0615iduo3+ and 720i super duo 3
Posted:
21 Jan 2012, 08:08
None of us here use duo chargers. But study the photos on my web page and spot the silabs chip. Its the 2 connections coming from the "top" side based on the writing that you need. I think...
Posted:
28 Jan 2012, 00:07
by andyp
Hi John
Thanks. All sorted with the help of Mr Mel.
0615i duo 3+:
- _DSC80~1.JPG (226.55 KiB) Viewed 28408 times
- 720i.jpg (242.34 KiB) Viewed 28415 times
Thought these pics from Mr Mel may help someone else....
Andrew
Posted:
28 Jan 2012, 00:08
Thanks, great. Will use those on the page!
Posted:
22 Sep 2012, 23:17
by Zhavener
Has anyone successfully installed a BT module in a 720i Super Duo 3? I am in the process of trying however when the charger is powered on I only get around 2vdc across between the USB case and the back pin on the temperature sensor port. I believe it needs to be at least 3.3vdc to power the BT Module. Also I am at a loss for locations to solder the Rx and Tx Wires.
Posted:
22 Sep 2012, 23:32
Never looked inside one of those.
Posted:
22 Sep 2012, 23:48
by Zhavener
Burgerman wrote:Never looked inside one of those.
Here is the left side of the board
From the pics from Mr.Mel it looks like VCC is from the temp sensor pin. GND is the USB case and Tx and Rx are R358 and R49 (just under the FAN connections) however I am not sure which is which and how to tell
Posted:
23 Sep 2012, 00:44
Tx and Rx I dont know either. Not without seriously folowing the traces, from that square chip. Its the same chip on all the boards. But I really would need the board here, and some timer to figure out exactly what was what!
Posted:
23 Sep 2012, 13:21
by woodygb
The component numbering system on the board is a little odd ..but you can see that the resistors under the word FAN are R211 and R119 .. exactly the same as the other pic.
Look at the group of components to the right of R338 4 resistors 1 cap 2 resistors and a "diode" ..you'll see above the 3 leged "diode" that the grouping is printed.
Posted:
11 Feb 2013, 21:03
by wareck
There is someone can make 720 super duo 3 working with the BT ?
Can you give me the soldering image ?
Olivier
Posted:
11 Feb 2013, 21:05
Dont think anyone here has one of those. We are all charging bigger batteries with more than 7 cells.
Posted:
23 Sep 2013, 02:34
by padrino
Using the great tutorial on the main site I sorted out the connections for the super duo 3.. I am mobile currently and don't have anything to markup the picture of the SDUO3 in the thread but.... If you look at the 0730i in the tutorial picture as a reference, it's the same layout but the RX and TX locations are swapped... Everything else works as is..
Posted:
31 Oct 2013, 00:11
by ogopogo
615iduo3 is a different animal as far as component layout goes. If anyone has location of TX, RX I would greatly appreciate it.
cheers, john
doh - scroll the photo John
- now I see it is on the underside !!!
Posted:
18 Jan 2014, 17:14
by sin85
how to pair or add hzperion as a device via bluetooth. what is the password.
Posted:
18 Jan 2014, 17:28
Depends on card.
Usually
1234
1111
0000
4321
If its non of those I don't know. All of mine are 1234
Posted:
21 Jan 2014, 04:51
by ex-Gooserider
Another option I've been wondering if would work (and why not if it doesn't) that might be a simpler approach, and avoid needing to do surgery on the charger....
I picked up a few USB - Bluetooth dongles at a cruft swap a while back - essentially they are a USB plug that is a Bluetooth module, intended for use with the few laptops and similar devices that have USB ports but no BT modules... My understanding is that it looks like a USB cable to the device it's plugged into. If it would work, seems like a simple way to add BT capability to an Hyperion without needing to open the box. (Though I have ocasionally thought of replacing the banana jacks on it w/ 30A Andersons as I really don't like using bananas for that kind of task...)
Posted:
24 Jan 2014, 18:19
by Mark
ex-Gooserider wrote:Another option I've been wondering if would work (and why not if it doesn't) that might be a simpler approach, and avoid needing to do surgery on the charger....
Have you tried it yet?
Mark
Posted:
24 Jan 2014, 18:20
by Mark
Mark
Posted:
24 Jan 2014, 18:35
Others have. No work...
Posted:
25 Jan 2014, 18:53
by Mark
Thanks BM. That will save me buying one (bluetooth usb adapter).
Also, sorry about the duplicated posts above.
Mark
Posted:
28 Jan 2014, 08:59
by ex-Gooserider
Haven't tried it yet - I've got lots of different projects I'm working on, and that one is pretty far down the stack...
Sorry to hear BM say that it doesn't work.
Posted:
28 Jan 2014, 10:45
Not me, some have tested it on the RC Models Hyperion thread.
Posted:
11 Jun 2015, 04:33
by miyage007
Zhavener wrote:Has anyone successfully installed a BT module in a 720i Super Duo 3? I am in the process of trying however when the charger is powered on I only get around 2vdc across between the USB case and the back pin on the temperature sensor port. I believe it needs to be at least 3.3vdc to power the BT Module. Also I am at a loss for locations to solder the Rx and Tx Wires.
I know that this is an old thread but it sounds like you have shorted both rx and tx resistors while soldering which may cause this voltage drop when you plug in the BT module.
Has anyone tried to replace these two resistors? Whats the specs of these chip resistors?
A friend of mine is doing this mod and got the module to power up but then did a bit of a mess soldering the rx tx resistors and touch each other which then causes the module not to power up anymore when plugged in as it only shows 2v now. Also, the EOS software doesnt detect the charger anymore from USB port after this. Is it a brick charger now or is there still chance of getting this to work?
Posted:
11 Jun 2015, 12:50
No idea.
Posted:
16 Jun 2015, 06:49
by ex-Gooserider
Get out your magnifying glass - MOST, but not all SMD resistors, especially in the larger physical sizes, will have values on them, using the standard 3-digit resistor code (2 digit value and a multiplier for the decimal place). It might be necessary to pull the part off and look at the underside if it was put on upside down.
Alternatively, lift the part and measure....
Wattage is essentially set by the physical package size, if you use the same size, that should be OK.
Posted:
16 Jun 2015, 08:47
by LROBBINS
Most chip resistors now use a 4-digit code, but you can easily find both the 3-digit and 4-digit schemes on Wikipedia. Unlike resistors, chip capacitors generally don't have their values marked. How hard it is to remove and replace an SMD component depends on how tightly the board is packed, and what tools you have available. With a small soldering iron, and a chisel tip modified to a kind of two-pronged fork, I can pretty reliably remove 0805 sized chips without damaging anything else if there's a bit of space. For smaller I think re-work would be very difficult without having a hot-air desoldering tool (which I don't have). Sometimes, when I know a chip is bad I destructively remove it by heating one pad and prying up with a tiny screwdriver. Sometimes damages a pad, but can usually patch that one way or another. I really do need to get a modern SMD soldering station, but I'm cheap. In general I find making SMD board far easier than making through-hole boards (and all I have for that is a cheap toaster oven, very fine solder that I flatten with pliers and cut into pieces, and some sticky flux). It's tedious to position everything, but then the reflow soldering is a snap. Repairs are another matter, however.
Ciao,
Lenny
Posted:
28 Jun 2015, 14:34
by ErZett
I had the same problem, but I solved it.
The reason is Hyperion changed the layout of this charger. The area for USB and the area the charger itself is separated with this optocoplers (
https://www.fairchildsemi.com/datasheet ... DM8061.pdf).
To get it working you have to use a separate power supply from extern USB or with a 5V fixed regulator. But you have really to supply Pin 1 from the USB so you get 3V on Pin 6 from the CP2109 to supply the Transistor (Q47) in front of TXD optocopler.
Also, you use this 5V to supply the BT-Modul.
RX from the BT is to connect to Pin 5 from the FODM8061 (PC1) close to CP2109. TX is to connect to Pin 1 from Transistor Q47.
That's it.
Rainer
Posted:
27 Jan 2016, 21:08
by Shumacher82
Hi! I'm from Russia! I have a problem with my EOS 720i duo 3! I want to connect my laptop with charger by BT module! ErZett, i found in datasheet points for connection RX and TX my BT module, i connect BT by external pover supply 5V! I dont understand what what to do next???
Posted:
27 Jan 2016, 23:45
Does it flash?
In windows does it find it?
See here;
http://www.wheelchairdriver.com/hyperio ... ersion.htmRead carefully!
Posted:
28 Jan 2016, 15:06
by Shumacher82
Hi! Yes it's flash! Firmware 5,94. I already read your massege carefuly, but electric schem of my charge has differences of schem EOS 1420
