Blue Tooth Wiring
Re: Blue Tooth Wiring
Postby Seajays » 30 Jan 2012, 00:55
Last post time for Pub, Dose this look right?
Seajays
Postby Burgerman » 30 Jan 2012, 01:52
yEP!
Postby Burgerman » 30 Jan 2012, 01:54
disable COM 8 IN DEVICE MANAGER. nOW IT SHOULD WORK.
Postby Seajays » 30 Jan 2012, 18:04
Nope, Have to open Hyperion Suite, click Bluetooth icon , select connect, then solid red light, close Hyperion, light stays solid, open Hyperion suite, light stats to flash. Won't stay connected. I think I will get a different Bluetooh and try again. This is what I have. The only one they had.
http://www.memoryexpress.com/Products/MX28934
Seajays
Postby Burgerman » 30 Jan 2012, 18:37
If it connects when you tell it too, then I suspect you still have something set wrong. Because it should automatically connect in around half a second. Does it work when you manually connect?
Is it in range? That may be an issue, some BT things are rubbish on range...
Is it showing ONE serial/bluetooth connection in device manager and ONE disabled connection?
It should only ask for password when you open hyperion software first time and not again, as this pairs it up.
You are doing something wrong. I think. Although it COULD be the BT dongle in your PC.
Postby Burgerman » 30 Jan 2012, 18:40
I configured my freinds 1420 (used for hobby stuff) yesterday on his laptop in the pub. Working first time. As easy as mine did. But he couldnt get it to work, so you are not alone.
Postby Seajays » 30 Jan 2012, 18:58
Two com ports , Com 10 - Disabled, Com 12 - enabled, sits next to computer, will work if manually connected , but after Hyperion starts, looses connection, then have to manually restart with Hyperion Suite open, then stays solid, close Hyperion , stays solid, reopen Hyperion , starts to flash when open. Have to manually re-connect.
Seajays
Postby Burgerman » 30 Jan 2012, 19:01
Then I dont get it.
Did it ask for password on opening hyperion? Or did you supply one when you initially found new device?
Did you tick all four boxes in bluetooth settings screen?
Postby Seajays » 30 Jan 2012, 19:26
No password for Hyperion, Did ask at one point, All boxes checked. Think I will give up or try new Bluetooth. Hyperion might not be for me.
Seajays
Postby Burgerman » 30 Jan 2012, 20:04
Try new bluetooth. When it works its easy.
Postby Seajays » 31 Jan 2012, 17:20
Bm, FIXTED IT !!, After 3 days of screwing around and ordering 3 new Bluetooth on Ebay last night , I finally found the problem in the Bluetooth settings. There was a check mark in the box, unchecked it and everything works fine. Bm, Thanks so much for all your help anf great patience with me.
Seajays
Postby Burgerman » 31 Jan 2012, 19:08
I dont have that screen, just looked? Or maybe I cant see it...
So now it works reliably? Dont you love computers?
Postby Seajays » 31 Jan 2012, 19:43
Bm, Yea my Mac hate windows.
Seajays
Postby Burgerman » 31 Jan 2012, 19:47
I did tell you it was a bluetooth setting though!
Postby Seajays » 31 Jan 2012, 20:13
Yes you did ,it just took a long tome for these old brains to come together to find it. When you get over 65 your not supposed to be thinking this hard. Starting to make uo my cables now. Thanks so much for this site and all you do for us. Can't wait for the BM 4.
Seajays
Postby Burgerman » 31 Jan 2012, 20:16
My brains are 52 as well. Hurts a little thinking. But my EYES are the real problem Or my arms are too short!
Postby Burgerman » 31 Jan 2012, 20:43
Well BM4 was about to be unpacked and re assembled, since its all done, seat and all. Months ago. But my wet room, bedroom, etc was getting rehashed. Now JUST as I start again my brother who fits bathrooms etc decided that his guys are at a loose end. No work. So now he will be here monday to move 2 walls, re plaster, re tile, refit new bathroom! Cant argue since its all rather "cheap" to put it mildly. So on hold AGAIN...
2 weeks from now he will be gone.
Then I can do the re assembly, (easy) and then the dificult but interesting stuff with the roboteq/RC/analog joystick, brakes, all at odd voltages with mini inverters, solid state relays, and scripts I dont understand! Yet.
Should be fun. And a little warmer. Need to get it done for april since traditionally I swap chairs and start another! But I have 4 now... And an old knackered battleaxe winter/mud/cleaning/mucky job one.
Postby Seajays » 17 Feb 2012, 18:18
Bm, Bluetooth in device manager working, all 4 boxes checked, linvor installed in device manager, all ports disabled except # 10, Hyperion manual port setting #10. power on Hyperion light flashing. Does the Hyperion light continue to flash until the Hyperion is turned on and charging ?
Seajays
Postby Burgerman » 17 Feb 2012, 19:08
If everything is set up correctly, and charger, computer etc have all been restarted since, it will flash right up until the BT version of the program starts. As soon as that happens it will stop flashing and connect. It will ask for the password 1234 first time only.
If this isnt happening you have something wrong.
Postby Seajays » 29 Feb 2012, 19:48
BM, Still can not get this Bluetooth working Can you give me a link to ..LATEST Hyperion Logging & Control Software
Seajays
Postby Burgerman » 01 Mar 2012, 11:19
www.wheelchairdriver.com/bt.zip
Is what I amusing, but its a special build.
The latest one from the hyperion site should work.
Postby nettraptor » 16 May 2012, 21:41
hello i have exactly the same problem
when i start the program Bluetooth module led turns SOLID red and and when program opens Bluetooth start blink again means lost connection
nettraptor
Postby Burgerman » 16 May 2012, 23:08
Try a different serial port number.
You did disable the "extra" port in the device manager? Not delete, but disable?
And you added it as no serial or code?
So that windows asks for it when the hyperion software starts? Then use 1234...?
When you get all correct, restart charger, PC, program, and it will work... Well it does here! On my laptop, and PC and 3 chargers (at once or on any computer individually)
Make sure its not a range issue. Or some serial port sharing issue.
Postby Seajays » 16 May 2012, 23:36
This sounds very familiar. Mine still doesn't work. I finally gave up.
Seajays
Postby nettraptor » 17 May 2012, 07:38
let me tell you what i use
Windows 7 home and HP laptop
this the module http://www.sunsky-online.com/product/de ... .id=213421
i bought 2 modules
1)i start the charger
2)search for BT from laptop
3)no pass
4)windows start to install 2 COM ports
5)disable the second installed port
6) i added 2 commands in short cut BT MANUAL
7)restart charger > start program
8)asking for the pass > i give the pass
9)give the correst COM port
10)restart program
opening the app... Now the bluetooth turn Solid Red.. i cross my fingers , when app opens Led blinks again...!
yesterday i try 2 different things
1) i start a Virtual PC with Windows XP and this didnt work either,
2) i close the internal Laptop BT and added a external usb Bluetooth again nothing...!!!
the only thing i manage is from windows XP i clicked to connect into the Hyperion from BT manager, and i connected successfully (Led Solid)
after that i start the app and again the led start blink!!!
There are 2 possibilities
1) the first time i solder the TX/RX of BT To the right side of the SMD transistor , when i saw the photos better i swap them to left side
2)a setting or something
nettraptor
Postby Burgerman » 17 May 2012, 11:30
reverse tx/rx wires. There seems to be no standard here. Some one way, some the other...
Postby nettraptor » 17 May 2012, 11:44
Burgerman wrote:reverse tx/rx wires. There seems to be no standard here. Some one way, some the other...
ok this is easy i will do it.
something else
when the program starts i manual select 1 com port , The first com port windows just installed for hyperion BT, correcT?
nettraptor
Postby nettraptor » 17 May 2012, 11:58
or do i have to select all the com ports available?
nettraptor
Postby Burgerman » 17 May 2012, 13:26
Easier than you think. The connecting plug can be reconfigured easily. Just swap the tx/rx around in the plug connector.
Where are you selecting these ports?
Inside the hyperion program? Then it doesent make much difference. It searches when the prgram starts anyway.
Postby nettraptor » 17 May 2012, 17:20
i swap them
but is worst is not even Stay solid
i tried my second BT but nothing...
this is the log file
Code: Select all
Booting up system: -- 2011-12-14
High Delay: -- 300
Low Delay: -- 200
COM Port watchdog is now activated
Detected: COM26
Init port at 9600 baud
Detected: COM26
Trying port: COM26
Port open test: COM26
Port open: COM26
Trying write to port: COM26
Error during inital COM check: The operation has timed out.
Secondary error during inital COM check: The operation has timed out.
COM26: Com traffic, detect:
Scanning charger pairs
Async call for update began
Uri done
Async call for update sent
COM26
Disposing update object
Threadcrashing update object
nettraptor
Users browsing this forum: Google [Bot], LROBBINS, optical10, shirley_hkg and 23 guests
