UnicornBurner wrote:Thank you BM for your observation about our ability to use 230ah batteries. We did not think they would fit, but low and behold the EVE 230ah do fit in our Jazzy/Quantum Q6 chair. And yes FJ, I did quickly ask my hubby to upgrade to 230ah.
Luckily the EVE 105ah did not go to waste, we were able to install them in a chair our friends use that takes U1 batteries. So if anyone out there uses the little chairs that take U1 batteries, the EVE 105ah will fit. You will need to make two packs of 4 EVE’s and an extended cable to connect them. It’s a tight fit, but a great lifep04 solution for small chairs.
Thanks you again to you all for your support and excellent observations.
UnicornBurner wrote:Hi Steve,
We used m4 X 16 set screws. The nuts are m4 locking nuts. The connecting wires are home made by us. The wire we used is #8 flexible battery cable and we soldered the terminals on and covered the solder joint with sharing wrap tube.
Is this what you were referring to? These were for our chair that uses U1 batteries and we converted to Eve 105ah.
UnicornBurner wrote:This one seemed promising. It seems configurable. Most pricey….of course. Thoughts?
https://www.amazon.com/gp/product/B0CMP ... A0R09&th=1
Burgerman wrote:APPEARS TO TRY AND BALANCE REGARDLLESS OF VOLTAGE. YOU DONT WANT THAT!
Users browsing this forum: Jay_x and 34 guests
