(2) The MDC1460 is a lower-powered single-channel controller that may be well matched to your scooter (> twice the power of your current controller may well be enough - John can you chime in on this?) and is a lot cheaper.
LROBBINS wrote:What do you need to control other than the motors? High-current contactor, brakes, backup beeper, horn, lights? Are you prepared to design separate controls for these if you can't do it all from the motor controller?
Burgerman wrote:(2) The MDC1460 is a lower-powered single-channel controller that may be well matched to your scooter (> twice the power of your current controller may well be enough - John can you chime in on this?) and is a lot cheaper.
Well, not sure! Depends on what he wants as an end result and the motor spec!
Burgerman wrote:Amps on the controller you have now?
Thank you BM.
I suppose what I could do is use the tortoise/hare button as a 24/48v boost switch via one of the Roboteq's digital inputs? That way in "tortoise" mode the roboteq would limit the motor volts to 24v.
But when on a level or downhill section I could select "hare" mode and the controller would deliver up to 50v to the motor?
I've got an old Robin amp clamp that I kept from work. I'm not sure if it does dc though, but I know it's rated to 2000 amps ac. Could I clamp it round one of the battery cables and measure the amps going to the motor?
It would be difficult to clamp it around one of the motor tails and still be able to see the amp clamp while riding along. It would still be difficult seeing it when clamped around one of the battery leads, but with the scooter's body work off I might be able to hang over the side of the scooter and see the amps when riding along flat out at 9.5mph in it's standard 24v form.
It might give me a rough idea of what the motor will draw at 50v 20mph. Because didn't you say double the voltage, it doubles the amps + a certain percentage to allow for the additional wind resistance at 20mph?
foghornleghorn wrote:Whenever I'm going downhill you can feel the wheelchair leaning on the motors to stop it rolling away to a spectacular crash at the bottom - is it charging itself every time?
foghornleghorn wrote:Now I want to find somewhere with a 30 mile downhill run and see if I get to the bottom still fully charged
LROBBINS wrote:(3) I did not see any minimum order amount for on-line orders, nor did I see any pricing in GBP.
Burgerman wrote:You dont know your motor specs.
Users browsing this forum: No registered users and 151 guests
