BM - Would i be able to charge my chair - both have lithium in the chair and ADD ON - but BMS is in the chair - the bounder - i though about it - what if i charge the ADD ON fully connected to the Chair pack that has the BMS ?
the PL 8 would balance my pack - and the BMS would balance the chair pack - Can that work ? or would the PL8 give off errors at the end when trying to balance ?
Ok so only charging from there XLR socket would engage there BMS ?
lets say it does bypass it - would it matter much ? since the PL 8 will balance anyway ?
seems as if this may be even a better option to charge it both at once and get a better balanced pack in the end ? assuming the PL 8 dosnt give errors
what harm can it do if it was tried once lets say ?
Burgerman wrote:For the BMS to work it has to be able to DISCONNECT the charger repeatedly over and over as it tries to pull down the high cell. So no...
if would work if i use the XLR socket on the chair with the PL 8 - that would shut the pl8 on and off also - i dont recall if it did last time used it that way
i though maybe the BMS itself just shuts off that one cell leaving the charger going for the others - with the stock charger - i did see it hear it shut off and on -
Burgerman wrote:Copper oxydises. Instantly. And oxides dont conduct. Better to use plated or stainless.
steves1977uk wrote:These...
https://uk.farnell.com/norcomp/680s13w3 ... dp/2294341
https://uk.farnell.com/norcomp/680s13w3 ... dp/2294339
https://uk.farnell.com/mh-connectors/mh ... /dp/358381
And...
https://www.ebay.co.uk/itm/Red-Black-10 ... 2757833058
https://www.ebay.co.uk/itm/Flexible-Sof ... 2455634617 12awg 2m
https://www.ebay.co.uk/itm/50M-Mtr-Roll ... 1271600804
shirley_hkg wrote: Temporary measure. See what result I'll get .
Users browsing this forum: martin007, Raro, woodygb and 126 guests
