FWIW, a while back I wrote to Revolectrix with some questions about hardware / software requirements on running a PL-8, given my objections to things Microsoft.... I got a very nice response, relevant bits copied below, with my questions and the responses in red...
1. I normally run 100% Linux on all my machines, I do not like or trust any Microsoft products as I find them
consistently insecure, unreliable and generally a pain to use. Do you offer any Linux support?
No, only Windows and
the CCS also requires MS .NET. 2. Do you know if it is possible to run the Revolectrix software under Wine or any other similar emulator? Will
it work on a machine using KVM or other virtualizing software?
We do not know.
3. What is the minimum version of Windows that is absolutely required? If I have to use it, I do own a couple
of 32-bit machines that run XP, and I'd like to use one of those rather than being forced to go out and buy a dedicated
box with something newer...
it will run on Win XP; no problem. Recommend you update .NET to the latest version before
you install the PL8v2 CCS App.
4. Is it required to have the Windows machine connected to the Internet to install the software? Is there some
way to download everything onto my Linux box and sneakernet it to the Windows machine? I believe that connecting a
Microsoft product to the Internet is about as safe as unprotected sex with a partner you KNOW has every STD in the
book...
We do have special, local install versions of all our software products.
1) Go to: http://www.revolectrix.com/downloads.htm
2) Scroll down to the Software Updates section
3) Click on the first link "All Products Software (CD Install versions)"
4) Follow the instructions under the link to perform a local install. Local installs are not eligible for automatic
internet updates which sounds like what you want. The CCS app you install using this installer program can not be
updated and I am not sure how old it is. If the firmware packed up in this installation is v3.31, then it is likely the
current CCS version. Since the PL8v2 is a mature product, it is not likely there will be any new firmware offered or
CCS upgrades. I think you should be happy with this method of installation.
5. Similarly, is it necessary to have the machine connected to the Internet to USE the software? (I am not all that
worried about getting updates, and really don't want ones I don't know about...)
No. If you install from the website,
you should still be able to run the CCS without being connected …So looks like I should be able to use the same mini-notebook with XP (all it can handle) that I use for the Hyperion, the P&G software, and other such limited use applications...
