Burgerman wrote:A battery in a car, anything from 12 to 30V works fine. You need a 35 A or more and 24V up to 30V to get maximum power which is a lot. But you can also run it from a smaller supply.
Hello Paul,
We have received your order online. Thanks for your business.
For the reason that Headway facotory temparily stop their plan to produce more 38140S 12Ah model since Jan(they said the demand is much lower than their other models), right now we only have some stock for this model. They don't produce it and may no longer produce this model even we order a lot.
So we are sorry for the inconvenience, and we suggest you to think about if you can use 38120S 10Ah model or 40152S 15Ah model which we can ship immediately.
Sorry for the inconvenience. And please kindly let us know your advice and we will work on it accordingly.
garriew wrote:Burgerman wrote:A battery in a car, anything from 12 to 30V works fine. You need a 35 A or more and 24V up to 30V to get maximum power which is a lot. But you can also run it from a smaller supply.
Would this be a good PS?
http://lipoconnectionsolutions.com/HP-2 ... 241500.htm
If yes, what would you chose for the charger type? and other options?
Mind The Gap wrote:UpdateHello Paul,
Have updated order to 58 40125s with 4 hole connecting plates, waiting for repy.
Paul
Did you order it w/ bullet connectors?Gnomatic wrote:I have that PSU with an EC5 connector. It works well enough with my PL8.
garriew wrote:Did you order it w/ bullet connectors?Gnomatic wrote:I have that PSU with an EC5 connector. It works well enough with my PL8.
So 89Ah returned. With the charger not violating the laws of thermodynamics, that means the actual amount of power returned to my pack is a bit less than that. So in a year on I've had a bit of degradation. I'm not surprised by that. A big heavy chair and a big heavy me, with a fairly small pack. I'm off pavement quite a bit, so I'm working the cells hard.
With the PL8 saying 89Ah returned, what's the best guess of the actual capacity of my 1yr old pack now?
shirley_hkg wrote:Cool connector. What's it called ?
crypmanii wrote:Has anyone on here converted an Omegatrac to Lithium batteries? I've been reading through this thread but with 174 pages of information its a little overwhelming. HaHa. I know its not a quick "plug & play" process to make the conversion. Is there a kind of walkthrough for making the conversion? Something like this may have already been posted, and if so I apologize for asking, but I just haven't seen it yet within the pages I've already looked at.
Any guidance would be greatly appreciated.
Thanks all.
Users browsing this forum: No registered users and 39 guests
