shirley_hkg wrote:Scooterman wrote:If possible would you be able to pick me one up Shirley .
I'll throw in one .
I'll throw in one .
SB50 with half a metre of 8awg cables @£2 only. Great deal and hassle-free .
Available in 6awg wires too .
Burgerman wrote:One good tug on the wires and off they will come...
Burgerman wrote:Thy are only crimped though. One good tug on the wires and off they will come...
LROBBINS wrote: a mini-torch
terry2 wrote:expresso wrote:You can just make your own cables - may come out even better than buss bars in the end - takes a bit more time but works when all else fails
They look great.
Have you got any links to the parts you used dude?
I waited a week so the guy could get the connectors. Now how he tells me it will be another 2 weeks
So I told him to send the cells asap.
If still available would you be able to put my down for FOUR of the 8 AWG size please Shirley. If I don't use all four on the conversion they will come in handy for a future project I haven't thought of yetshirley_hkg wrote:
Scooterman wrote:LROBBINS wrote: a mini-torch
I'm going to get myself one of them if I've got any money left after I've given it all to Shirley
Scooterman wrote: would you be able to put my down for FOUR of the 8 AWG size please Shirley.
shirley_hkg wrote: But bespoke items may cost you even more , I guess.
You should get yourself spare SB50 bare plugs too. They are cheap here , & lots of choices .
expresso wrote:terry2 wrote:expresso wrote:You can just make your own cables - may come out even better than buss bars in the end - takes a bit more time but works when all else fails
They look great.
https://www.waytekwire.com/item/36568/H ... yelet-Lug/
this is what i used with 8 awg wire - crimp - solder - heatshrink done - take a bit more time but its solid when done - you can use thicker on the power cables if you like also 6 awg and leave the 8 awg for the rest of the connections -
https://www.alibaba.com/product-detail/ ... 36769.html you can try them also -
shirley_hkg wrote: @Scooterman , bought you 4 sets ; 2 with ring terminals / 2 with bare cable ends, 4 extra 50A Andersons.
Less than £12.00
shirley_hkg wrote: I'm gonna use this 0.5mm self-adhesive fibre paper as insulator between cells. Cheap , robust and easy to work with .
Scooterman wrote:shirley_hkg wrote: @Scooterman , bought you 4 sets ; 2 with ring terminals / 2 with bare cable ends, 4 extra 50A Andersons.
Less than £12.00
Cheers thanks Shirleyshirley_hkg wrote: I'm gonna use this 0.5mm self-adhesive fibre paper as insulator between cells. Cheap , robust and easy to work with .
Shirley I've been looking at the cell terminals, and as you obviously know the threaded hole isn't very deep, probably about 5mm-7mm?
Rather than using bolts I was thinking of using locktite with something like 15mm M6 stainless grubscrews with a nut, washer, and spring washer.
It would create a 'post' terminal. I have plenty of headroom on the scooter. And once the grubscrew is locked in place it would never need be removed if the cells had to be disconnected at a later date.
From past experience I've learn that aluminium threads don't like being disturbed too often.
I can't remember what I asked you to get me regarding bits And bobs. But if you've bought me bolts that's find I'll still take them. I'm not 100% committed on the grubscrew idea, I was hoping to get your's and others opinion first before committing on it.
swalker wrote:The specs for the 176ah Prismatic cells I have on order call for an M6x7 bolt.
I have found various lengths of stainless M6 bolts at my local hardware store that I think will work. I won't know for sure until I receive the cells and can try various sized bolts in them.
I am quite concerned about someone over torquing the bolts and stripping out the aluminum threads in the cell.
swalker wrote: do you have any concerns about the potential for exposure to water or high humidity?
expresso wrote:swalker wrote:The specs for the 176ah Prismatic cells I have on order call for an M6x7 bolt.
M6 is the bolt size and the 7 is the length ?
if so - you would want to have about 1 inch sticking up ? this is something to consider when checking the specs if they fit a chair or space anyone would have -
shirley_hkg wrote: I haven't bought your bolts .
I'm doing the same ; implanting a stud, with T2 pure copper parts instead of stainless steel . Aluminum threads are weak after all. Better conductivity counts .
I bought these myself .
shirley_hkg wrote: It's the PITCH of thread .
Users browsing this forum: No registered users and 116 guests
