Burgerman wrote:If it STILL wont play then an older silabs driver like 6.1 (I have) may fix it.
Not Found
The requested URL /silabs.zip was not found on this server.
Burgerman wrote:Or just do the BT thing. That doesent care about any of this stuff. It just works... At least it does after the initial fight to set it up. But once you get this right once, its easy. I have done a few for freinds and every one took about 20 mins including fitting the board. All working great.
LOl, would cost me at least 2k to bring it to you. I use a BT dongle, will try another and also switch the wires, but the BT module is the same as yours. If I select the middle option, use pairing code it will ask for the 1234 code and pair up. It also added 3 com ports, 6,10,11.
Users browsing this forum: Burgerman, Qvickster, UnicornBurner and 17 guests
