woodygb wrote:Adam,
You can load your par file into the later 1314 pc programmer and get a MUCH better look at the parameters as it has a a clearer menu/interface AND HELP...so you should/will get a better understanding of the displayed parameters.
BUT ... You can only save any changes that you make as a later file type which is NOT backwards compatible with the early 1314 version. ...Just use it as a learning tool.
Woody in G.B.
Thanks woodygb,
Its a good idea. I saved the .par file and opened by par file edit tool, edit and save but can't send to chair.
I try to remove the red light on my second Q6 EDGE, seems no that lucky, the power base parameters didn't show up the items be able to modify as picture 'seat navigation', its just '?', don't even have any actuators item, guess may because when the chair power up, shown error #225 the aam is missing?
I gained lot of:
1) the small 4pins connector to motor I mentioned before is for the encode, yes, they do have encodes for speed calibration see 'speed calibration'.
2) nearly all parameters of the motors are available to modify see 'polarity inverted' , 'motor swap', even 'gear ratio' these three pictures make one page as 'motor par' for the number limit, I really don't understand how can 'gear ratio' be changed ?
3) the voltage to brakes and actuators all are changeable.
Best
Adam
