woodygb wrote:Found the thread ...similar control system but NOT the same.
https://www.wheelchairdriver.com/board/ ... =4&t=11297
alfiepink wrote:BulldozerDK wrote:woodygb wrote:Yes ...
You need the Industrial software for the SOLO.
I have to ask two questions;
First of, I've tried reading through hundreds of contributions on this site, some of it gives me some insight, but I cannot seem to find a conclusive answer to the two questions I am sitting with;
First of all, In order to make a communication cable for the Solo driver would I need to just take a regular USB-> Serial adapter, connect the 4 pins to each of the 4 pins on the controller or do I need to find the diode and and install it connecting the TX and RX cable to one pin on one of the controller?
Woudl I need to modify the USB->Serial connector in anyway? And how? - or would I just need to use a direct USB cable with no serial adapter in between? Connecting the same parts?
SEcond questions, everywhere is mentioned that for programming the Solo controller I would need the industrial software, but I can't find a single place explaining where to get this software? This might be obvious for some people, but apparently I am lost at this point
I am sure that both questions have been answered before in the forum, but I simply can't seem to find the conclusive answers to any of the two questions.
I sincerely hope that someone will be able to assist me creating the adapter and getting hold of the software. - Thanks in advance!
Hi is the industrial software same as manufacturer software for the solo controller as this breeze i have got has this same controllers
Best regards
Users browsing this forum: rickystyx, scottnj@gmail.com, shirley_hkg and 22 guests
