Hello,
I'm hoping someone can please help me with what is probably a very easy problem:
I needed new batteries for my chair and was hoping to get just 50 Ah ones but all the store had were the more expensive 80 Ah ones. It was much more than I needed but I bought them anyway, brought them home, hooked them up and just as I was about to attach the charger I noticed that the front of the charger indicates "for rechargeable batteries 28-60 Ah". "Oh no, I have 80's!" I looked on the back of the charger and amongst all the caution and danger warnings it also indicated:
"Caution: This battery charger is for use only with 12 cell (24 volt) 28-60 amp-hour, gel cell batteries. Other types of batteries may burst causing personal injury and damage" They seem pretty serious about warning me that I shouldn't use it for my batteries. Now I'm in a bind because I can't return the batteries (it had single lead posts which had to be drilled to mount the fuse).
What will happen if I use this charger on my chair/batteries? Do I need to buy a new charger?
The old batteries had no Amp-hour rating on them so I don't know if they were also 80's, but I suspect they were substantially less.
My chair is: Invacare Storm Arrow MKIV
Old batteries: "MediChair MK Deep Cycle" part # 8G24
New batteries: Haze 80 Ah, Group 24 Deep Cycle Gel
Charger: Invacare model: BAT-GC0811, 24 volt, 3.8 Amp.
Any advice you could offer would be greatly appreciated!
Dave
Vancouver, BC
