Burgerman wrote:I correcxted the above. Re read!
Those batteries are crappy so no big loss but you could try it.
the $$$ is a loss ... it would still be be good for my scooter though compared to that sealed leaded junk I had.
m
Burgerman wrote:If the scooter is 12v. It will give a small 20Ah battery. If its 24v it will give an even smaller 10Ah 24v battery.
Burgerman wrote:So you SHOULD be fitting 40 or 45Ah of lithium in the same space. This is the entyre point of lithium. Its about twice as energy dense.
Fitting the same Ah or less than you had before, is just an expensive way to achieve very little. And the more Ah you fit, the lower the C rate of cell is needed and the easier time they get too. So it makes them last longer, have a lower average discharge rate, which also makes them last longer. Or charge just a couple of times a week, so 2k cycles means 20 year battery life...
To the best of my knowledge, Li Ping has never revealed the source of the LiFePO4 cells used in his arrays. Li Ping has always maintained there isn't a LiFePO4 cell made anywhere in China that he is not aware of, or has not tested for suitabilty. Given this, I think it's unlikely that better cells than his are available.
It has always been believed, the reason his batteries are so reliable, is his deep understanding of how the cells perform, and this is why he designs his own BMS. In fact, I would think the reason his batteries are so successful is due mainly to his management system.
I wanted to test pings using the powerstroller , but how easy are they to open or safe ?
Burgerman wrote:Because people are ignorant.
It isnt possible to design a BMS that works CORRECTLY for:
a) ANY 2 different applications. For a list of reasons there isnt room for. + A BMS is only needed if you are ignorant of batteries and to save you from damaging them through this ignorance, due to lack of C rate for the applcation, or through early/late low volt cut off since they dont know the load.And:
b) to balance cells to a high degree of accuracy during the last part of charge. LiFe cells really dont like over voltage. To do that Accurately needs an integrated charger/balancer. Not a BMS and a dumb charger. It absolutely must be logic controlled, and never allow a cell to go higher than thour charge voltage. ALL passive non integrated BMS balancers allow cells to exceed this when charging as the balancer cannot slow down the charger and cannot sink enough current. Typically just .1 to .3 of an amp... While the charger is piling on real amps. Many allow 3.9 volts. plus or minus a huge amount! Equals very short cell life in many applications. Like tens of cycles instead of thousands.
Burgerman wrote:I wanted to test pings using the powerstroller , but how easy are they to open or safe ?
If you have to ask this question then I suggest you do a lot of reading and hands on electrical/battey experience.
Burgerman wrote:a) they all maybe use a common "ground" and if so there will be smoke.
b) a cell phome charger charges at around .3 to .5 of an amp, so would take 60 hours minumum to charge just a 20 Ah battery and it would likely never end since self discharge rate at the full charge voltage is too high.
c) a cell phone charger is typically 4.2 volts, for lithium ion cells, as is my camera, laptop cells etc. We need 3.6.
You could use some bigger single cell hobby chargers, as long as they had a FLOATING OUTPUT and were not tied internally in any way. But then you have just as many wires, and 4 chargers. How is this better than one charger with balance connector?
The BMS has resistors that drain power from the fully charged cell groups while the low one's catchup, the problem is that this happens in milliamps ( ie: SLOW.... ).
Using a cell phone charger can speed up ballancing drastically, by charging each cell group directly via the ballance leads or the cell terminals directly you can get the job done way faster..
WARNING : most cell phone chargers will want to charge to 4.20v, your ping pack has lifepo4 cells that will be fully charged at 3.65v .... .
so using a regular cell phone charger you need to keep an eye on things and pull the plug at 3.6v.. it's ok if it goes up to 3.9v.. and not a huge deal even if it does hit 4.2 but try to prevent it.
Burgerman wrote:http://batteryuniversity.com/learn/article/how_to_prolong_lithium_based_batteries
This relates to lithium ion cobalt rather than lithium ion phosphate or lithium ion polymer. So not 3.6 but 4.2v cells. But the exact same thing applies to LiFePO4 cells although that site is a bit out of date.
Note on graph what going over the cells voltage does to cycle life
This is why the hobby industry use balance chargers and exact accurate cell voltage control.
What kills lithiums?
Over discharge.
Too high C rate discharge.
Too high C rate charge.
Heat. Cooler is better.
and the biggest one? OVER VOLTAGE...
These are 3.7v lithium ion cells. So should be charged at 4.2v. LOOK what happens when they go over by just a tenth of a volt!!! Now you see why I charge my LiFePO4 cells to 3.450v EXACTLY? Because 3.600 volt adds under a quarter of 1 Ah. And means a shorter life. Lithiums live forever if kept cool and away from full or empty. Over 3.600 volt is damaging for LiFePO4.
Burgerman wrote:The link goes to a cheap and nasty 10 cell charger?
I have spent 3 years and endless firmwares testing and developing and helping/advising to get the hyperion charger as good as it is. So wouldnt and couldnt recommend anything else. Because I know how crappy most are!
Burgerman wrote:They make a 24v 480 watt version. I have one. It allows you to use about 70 percent of a 1420 hyperions capability.
1420 Hyperion operates from 9v to 29 volt. It operates at maximum power (550 watts output, 650 watts input depending on output voltage) on 24 to 29 volts. With a 12v supply it can only give about 2/3rds power.
So best to get a 480 watt 24v version, and adjust its "voltage screw" to maximum. Which is about 27.2 volts. Looks exactly the same. That way you can charge your 12v pack at 20 amps.
Burgerman wrote:How are you going to connect two 24 volt power supplies? Unless set to the EXACT same voltage only 1 will provide all the power, the other will be idle. If you are going to mess about joining two together (and I wouldnt) I would use two 12v ones in series. But then there are isolation issues...
Better to get one that is adequate.
Users browsing this forum: mrgus2u and 80 guests
