rover220 wrote:Had a new I level in this week with q logic. The Curtis handheld I have for otto bock chairs will not work on q logic. Will try 1314 pc based programmer next week hopefully.
woodygb wrote:rover220 wrote:Had a new I level in this week with q logic. The Curtis handheld I have for otto bock chairs will not work on q logic. Will try 1314 pc based programmer next week hopefully.
I assume that the Ottobock handheld was suitable for the EnAble50 ?.,,,, NOTE:-The EnAble40 has the same 5 pin plug but uses a serial protocol rather than CAN.
Prog Access Econ-w allows the Q-Logic 3 to be programmed by a dealer of medical equipmentthrough a paired Windows device. Prog Access Econ-w must be enabled to allow the dealer of medicalequipment access to the Q-Logic 3 parameters for adjustment. If Prog Access Econ-w is not enabled(even if the dealer of medical equipment has been paired with the Q-Logic 3 previously) the Q-Logic 3cannot be programmed by the dealer of medical equipment.
Prog Access Econ-i allows the Q-Logic 3 to be programmed by a dealer of medical equipment througha paired iOS device. Prog Access Econ-i must be enabled to allow the dealer of medical equipmentaccess to the Q-Logic 3 parameters for adjustment, if Prog. Access Econ-i is not enabled (even if thedealer of medical equipment has been paired with the Q-Logic 3 previously) the Q-Logic 3 cannot beprogrammed by the dealer of medical equipment.
Burgerman wrote:http://www.wheelchairdriver.com/
I modified my index page to add your info rover. That should cheer up pride!
firehopper wrote: I dont have a program lead yet.. I ordered one that looks exactly like the one in the first post also..
Users browsing this forum: No registered users and 307 guests
