Sully wrote: They control different models of motors, but motors are dumb I don't think they care what controls them. They only care that they get enough power supplied to each motor . .
What I can’t easily find out is how much Amperage is actually going to the motors, from either controller. This is the wrinkle. I want to use the better and most powerful of the controllers I have available to me.
Now brakes, If I put 24VDC to either controller I should be able to find out what voltage the brakes run on by using a multi meter in the brake plug and energizing it. Same applies to both controllers.
Thndrwhls wrote:Gentlemen, I'm back at it with my old Arrow, it currently has MK4, with 4 pole motors. I am looking to upgrade the controller and joystick to say MK6 90amp, do I need to change out the 4 pole motors as well? Or just the connectors?
I've been searching the threads and this one is the closest I have found but still confused on motor connectors.
Thanks in advance
ex-Gooserider wrote:Thndrwhls wrote:Gentlemen, I'm back at it with my old Arrow, it currently has MK4, with 4 pole motors. I am looking to upgrade the controller and joystick to say MK6 90amp, do I need to change out the 4 pole motors as well? Or just the connectors?
Thanks in advance
Motors should be fine, no problem. If swapping connectors, I'd go with the small 15/30/45A Anderson Power-pole units with the appropriate contacts. On my Ranger project chair, which was born with MKIV that is what was already on the motors. (It now has a 100A Pilot+ setup)
ex-Gooserider wrote:This sort of fade and recovery after sitting a bit sounds to me like a battery issue - are you still running on lead bricks?
What happens with those is that when you run moderately hard, you pull the charge off the surface of the battery plates causing them to act like deeply discharged. Then when you sit for a while, the chemical reactions penetrate into the plate coatings and balance out the charge so that the surface acts like it has recharged.... This sometimes shows up on a chair as losing some of the battery LED's as you are running, and then having them come back on while sitting. Its the same reason why if your car runs the battery down while trying to start, you can get a bit more cranking after letting it sit for a few minutes....
This problem is worse in gel batteries and gets worse as they age.... The lead fix is to go to Odysseys, or better yet go to lithiums instead.
The controller overheating tends to be either stopping or massive power reduction, not just a pause, until the controller cools back down.
Not sure what the best replacement controller is, in part because I'm not sure what the old MKIV controllers had for outputs in the first place...
On my H-Frame (Ranger-X) project chair, which supposedly has the 4-pole, 6mph motors, I went with a 100A Pilot+ power module. This is because I'm used to the Pilot+ series, have the software for programming them, etc. The 100A units are hard to find, the 85A units are much more common, and probably would have done the job.
Note that none of the controllers deliver the claimed current for very long, all just put out full power for only a few seconds before 'rolling back' to a lower level.
ex-Gooserider wrote:Not sure - but if you have a wiring harness with the ends that connect to the power module, there is no reason you can't chop the other ends off and fit whatever you need to match the motor cables, (Which on my chair used the 15/30/45 size Anderson Power-Pole shells with the corresponding contacts for the wire size)
If you don't have the harness, you might try calling around to the various chair salvage yards (look for ebay vendors with lots of chair part listings) and see if any of them have a harness - likely as most don't list a lot of the parts they get.
The other option if you can identify the connectors used (I don't know what they are, others here might) is to get new connectors from a parts house like Newark or Digikey, and make your own harness to fit your needs...
Burgerman wrote:Dont worry about windings, as all the 4 pole motors can pull more Amps than a mobility controller is electronically limited to.
So at stall, and at full power your motor will be sat at around 6 volts (say a pulsewidth of 25 percent from your 24v battery.) Why? The controller and power module measure the Amps, and limit you to 90A max, by reducing pulsewidth. Thicker and less turns on windings = more Amps at any given voltage. So it WOULD theoretically give more torque, but now all that happens is that the motor Volts are lower at your limiting 90A... So torque remains the same. However battery Amps have fallen and are lower at the same 90A motor current. So you gained efficiency. You also gained RPM, so higher speed when free running. So lower impedance = better efficency. You may want to read this twice!
So torque is limited by 3 things.
1. The motor impedance must be low enough to pull full 90A from your controller at stall. Lower still = no gain in stall torque. But efficiency gains.
2. Gearing. A 4mph motor all else equal, has double the torque of an 8mph one.
3. Power module max Amps. I use R-Net and pilot plus. 120A and 100A. In reality both almost as good since the 120A is just a few seconds boost.
shirley_hkg wrote:You don't really need the SD card .
Programmer alone will do all of it .
Users browsing this forum: No registered users and 12 guests
