Burgerman wrote:Those are not tubeless rims. You can knock a tyre off... Admittedly its hard. Unless at very low pressures.
Burgerman wrote:Yes. It does.
When drag racing bikes, I had tubeless rims, but it spun the wheel inside the tyre partly because it had about 400 hp, and partly because I ran it at 4 to 5 psi-- ripping the rubber tyre beads up and destroying the tyre on a launch/run. It happened twice. After the tyre fitter used some unknown tyre fitting lubricant. Others had similar issues now and again.
It probably wasn't required, but not being made of money, I decided to fit the tyres myself! And used a contact adhesive as the "lubricant" when fitting the tyre. This was the consistency of dish soap, and was "stringy" if you know what I mean. Easy to apply by finger... http://www.bostik.co.uk/diy/product/evo-stik/Impact/6
Clean de-grease rim. Clean tyre bead with a damp cloth using lighter fluid (white spirit). Apply a THIN film of the adhesive to the tyre bead on outside edge, and the inner ring where it sits on the wheel. And a thin film on the rim, where the tyre bead will sit and push up against the edge of the rim. L shaped!
Fit tyre fast. Its essential as it dries in 5 mins. Inflate to the correct pressure or more to seat it. It goes BANG twice. Excess glue squeezes out. Never ruined another tyre. But they are a bitch to get off. You need a professional bead breaker. So take to a tyre place. The same lighter fluid gets all the excess glue off the tyre or rim easily. Old cloth and a good splash.
Burgerman wrote:Looking for every type and colour of bolt, spacer, on stainless or alloy? For your ultimate powerchair build?
http://stores.ebay.co.uk/GWR-Fasteners?_rdc=1
Burgerman wrote:Why not? I have many times. Dont tell them you are an end user. Dont ask dumb questions. Just ask for a price. Preferably to the supplier to your own country.
Burgerman wrote:https://support.pgdt.com/Customer-Services/Mobility-Accredited-Partners-and-Centers.aspx
Here
Welzorg Nederland BV
Heathrowstraat 5
1043 CE, Amsterdam
Netherlands
Tel: +31 (0)36 545 86 00 | Fax: +31(0)36 545 86 30
Emails : Info
www : welzorg.nl
fishinjunky wrote:are these cable sizes sufficient for a 8s x 230ah pack?
6awg for connecting the cells instead of using bus bars.
10awg for charging cable.
10awg for cable going from battery pack to power module.
thank you,
Users browsing this forum: daveonwheels, LROBBINS, swalker, woodygb and 24 guests
