Postby Mikeclayton » 22 Mar 2021, 19:10
Hello! I am also among the many in search for the software. Making the cable now. :)
Thank you in advance!
Mikeclayton
Postby Burgerman » 22 Mar 2021, 19:34
See PM
Postby Bianko16 » 25 Mar 2021, 16:18
Hi all!
I’m making an electric scooter for my grandson by using the motor and other thinks recovered from a weelchair broken...
The driver unit is a S-drive 120A and I try to reprogramming it by using the software pg with dealer mode, but the function that I need to change are not mentioned with the dealer privilege...
I read in some post that there are the o.e.m and manufacture privilege for the software, someone has this software or can help me to found it? Thank you in Advance
Bianko16
Postby Burgerman » 25 Mar 2021, 17:43
Not sure about scooters, if woodygb doesent sort you out then I will have a look!
Postby woodygb » 25 Mar 2021, 17:45
Burgerman wrote:Not sure about scooters, if woodygb doesent sort you out then I will have a look!
I will send a P.M.
Postby tetsu » 22 Apr 2021, 14:46
Good afternoon,
I am also interested in having a look at the software. Do you happen to have a link to it?
Thanks a lot in advance!
tetsu
Postby Jadams » 07 May 2021, 15:12
Hi Guys, new to the forum.
I have a mobility scooter, namely a Sterling Diamond. Had far to many issues to mention but mainly the original controller has been repaired twice (both braking issues) over the last 2 years, and yet again, the controller has gone (all different errors). I have lost faith in the Pihsiang controller, so I am converting the motor drive and electronics to the S-Drive (120amp). I will be fitting it to my original motor and brake assembly, and would like to know if it is possible that someone could please send me the PC programmer software, as I will need to alter the configuration for braking/de-acceleration, reverse, buzzer etc.
your help would be very much appreciated
Jeff
Jadams
Postby woodygb » 07 May 2021, 16:07
You have mail.
Postby clatello » 11 May 2021, 14:49
Hello,
I'm looking for the OEM software to programming a PG Drives Technology S drive controller.
Can anyone help me?
Thanks, Jens
clatello
Postby woodygb » 11 May 2021, 15:18
Check your messages
Postby Francoisc » 11 May 2021, 23:51
Goo day I have s-drive s200a controler and un searching for the right program to config ,the robotic shop send me the dealer version but I’m not sur if the right one I need to configure the parameter can you help
Francoisc
Postby woodygb » 12 May 2021, 14:18
NOTE:- The software requires YOU to designate the CORRECT Coms Port and the Com Port number assigned to the programming lead MUST be between 1 & 8 inclusive.
The software may initially complain that it is
unable to open serial port
Follow the pic ...click Continue ...click Tools ..then Comms
Postby Olivier » 25 May 2021, 02:53
Where to find Pc mobility programmer software for m'y wheelchair?. :thumbup: thanks
Olivier
Postby Burgerman » 25 May 2021, 08:14
Check PM
Postby Aidan378 » 07 Jun 2021, 09:11
Where I can the programmer has everybody a Link ? Thank you
Aidan378
Postby Stern-300E24V » 21 Jun 2021, 10:40
Hello people,
my name is Joerg (short version of Georg) and I come from Germany.
At first, sorry for my pour English !!
I have an Problem with an "invalid Chairs" from my Mother.
So i want to change the Controller, because i think the old one is defect (Faulty Motor Connection but the Connection and Motor is okay !). I have an other Controller (S-Drive S140) from a friend, but i need to "reprogramm" it (e.g. Throttle Type, Motor-Parameters etc.)
I tried to fix this by a wheelchair service near me. But they does not have the equipment to do this (or they dont know what i wont :-( ). So I try this way.
To Solder the Cable is not the Problem, thanks for all the Information here in the Forum !! But i couldn`t find the OEM Programmer Software, only the Dealer Version :-(
Can someone help me ? :worship :worship
Best Regrads
Joerg
Stern-300E24V
Postby Burgerman » 21 Jun 2021, 10:59
Who manufactures your control system?
What exactly is the controller?
Postby Stern-300E24V » 21 Jun 2021, 11:14
the Controller is a PG Drive Systems D51140.04, in the Documentation they are Called "S-Drive 140".
Because its a PG Controller, i asked here for the Software tho reprogramm it. I can get the Params for the Motor also from the Documentation from the "inavlid Chair".
Stern-300E24V
Postby Burgerman » 21 Jun 2021, 11:31
Does that need industrial or standard programmer? Best to wait for woodygb I know almost nothing about scooters.
Postby Stern-300E24V » 21 Jun 2021, 11:35
czy i dont know, i think the Industrial (OEM), i think the "Standard" is the Dealer Version an can not change these Params....... so will wait for Woody :worship
Stern-300E24V
Postby woodygb » 21 Jun 2021, 11:48
Joerg ... There are 4 levels of mobility software User , Dealer ,OEM and Manufacturer.... there might also be a FACTORY LEVEL.
There is also some software called INDUSTRIAL , this software suits a small sub set of industrial controllers that are sometimes used on mobility scooters.
You want the Mobility Software .
Check your messages.
Postby Stern-300E24V » 21 Jun 2021, 12:27
Hey, cheers Thanks very Much !!!
One Question: is this the Correct Wiring ?
Stern-300E24V
Postby woodygb » 21 Jun 2021, 13:22
Yes ....here is the latest that uses a Schottky diode
download/file.php?id=15638&mode=view
Postby Stern-300E24V » 21 Jun 2021, 13:29
You`r the Best !! :worship :worship
I will try it with an CP2101 USB to RS232 and an 1N5819, because: i have both items here....... i will report...
Stern-300E24V
Postby steves1977uk » 21 Jun 2021, 16:18
PGDT released version 14.8 for Dealers. Anyone got the OEM or Manufacturing version of 14.8 please?
Postby Stern-300E24V » 29 Jun 2021, 06:09
Thanks for Your Help and for all the Information here in the Forum !
The new Controller works now, and my Mom means, its driving a littel bit faster as with the old one ?!? I read the Params form the Old Controller and wrote it to the new one, i changed nothing..... Dosn`t matter, it works !
The Cable (Link somerwhere here in this Thread) works and the CP2101 works also with this Cable and Controller !
Stern-300E24V
Postby berkayemin3 » 14 Jul 2021, 14:11
So where can I find PG Drive mobility programmer ?
berkayemin3
Postby kityweels » 15 Jul 2021, 18:32
hi everyone
I have a AFIKIM BREEZ with a SOLO D50960/1, and a AFIKIM S4 with a S-DRIVE D51446.05 controller.
I need the OEM software in order to program them, and as written before, I guess I need the "INDUSTRIAL software"...?
will it be good for both?
where can I get it?
Yoav
kityweels
Postby marc.rudorfer » 27 Aug 2021, 15:12
Hello @ all I have a S-Drive too and I need to change a few parameters but I only have the dealer software and so I have not many options to set.
The cable works fine ( I read about it. in this forum and made one that works really perfect) ;)
Only the problem I need the right software for setting all up right
I hope someone can help me to find the software
regards from Germany
Marc ;)
marc.rudorfer
Postby woodygb » 27 Aug 2021, 15:54
Users browsing this forum: Jay_x, mentado020477 and 34 guests
