paulgato wrote:You could also put those fuses in this type of fuse holder...
http://www.12voltplanet.co.uk/midi-stri ... older.html
...This is a UK site of course but I'm sure these are available in the US very cheaply too. I've used these fuses and holders and they work well. I initially tried bolting a midi fuse directly to a battery terminal without a holder but I found that too insecure and wobbly as the fuses are not that physically strong, and moving the wire around would bend the fuse very easily. You can bolt the holders down to a surface, but they also work perfectly well just left hanging on the cables. You could, for example run a very short wire from the fuse holder to the battery terminal with ring connectors of on each end (5mm for the fuse holder end) ...and then a slightly longer cable on the other side of the fuse/s could go to a two-pole plug/socket (possibly similar to the ones in your photo) so you can simply plug the charger lead in and switch on the charger, with no risk of anything bad happening. Heatshrink sleeving over the ring connectors ensures that no metal is exposed. Blu-tak (use a large, wide lump of it!) is quite good for sticking fuse holders and/or two-pole plug/sockets down onto the battery to stop them floating around, but leaving them loose is fine too.
paulgato wrote:...Oh, and fast-blow or slow-blowfuses...?
The standard ones you bought are slow-blow and are fine. The principle is that you are protecting the CABLE in case it short circuits the BATTERY CURRENT, which can be many hundreds of amps. The value and type of fuse you choose has nothing to do with the charger output in this case, except that of course it must be a higher value than the 20A the charger will put out. You are using 8 guage AWG cable, which is fine for a short length of charger cable carrying 20A. 8 guage cable will safely carry 40A, but anything over about 50A and it will start getting hot. So a 30A fuse is just fine (...and anyway I believe 30A is the smallest value you can get in the midi fuse format).
But if you were using fatter cable, say 4 guage or 2 guage, then you could safely use a much higher rating fuse. The point is that the fuse must blow before the wire gets dangerously hot, and a 30A fuse will do that. A slow-blow 30A fuse won't blow instantly at 31A, but it doesn't need to, as the wire won't get hot instantly either. As a rough guide, a standard 30A fuse will blow more-or-less instantly at double its rated value (60A) and will blow after a minute or so at slightly over its rated value.
Now, just in case you were in any doubt what can happen if a pair of large 12 volt batteries shorts out, here's a video of a guy welding some large pieces of steel together using a pair. This guy knows what he's doing and it's a controlled situation, but the fuses are to stop this kind of thing happening due to a chafed or pinched cable when you're asleep in the next room...
https://www.youtube.com/watch?v=PV5oLPLUzrM
The fuse in the charger will protect the charger, and only the charger, from a short in the wiring to the chair or in the chair. The fuse in the chair will protect the chair from a fault in the controller or wiring from the battery to the controller. The new fuse will protect the new wiring and chair and you from a screwup or short in the new wiring.i was also told the charger which is fuses input and output with a 30 amp fuse also - will do the same thing - protect the cicurt and charger in the event of any short etc, - now i am not an electrican - not even close when it comes to wiring etc,
YES. If connected as explained here, if it blows you won't be able to use the quick charge connector, but you will be able to use the chair and also charge through the regular charging port. If it blows, you shouldn't be using the quick charging connector anyway until you find out WHY it blew.my other concern then is - if the tech does add this fuse i just purchased - and it blows for some reason - i wont be able to charge with the wires i added- BUT would i be able to still use the chair and chair on the chair port like normally ?
Zero, unless something cuts through and shorts the wires or the chair controller goes completely haywire - in which case you have other, more serious, problems than a blown fuse.what are the odds of the fuse blowing if all wires made well and connected correctly ?
expresso wrote:you know - its a good thing i called and stopped my order - i reordered a fuse holder with a fuse - its a little different - but one end of the fuse holder bolts to the post - and other end would be my cable with the fuse in the middle
so much happening so fast - so many options if i had the time to figure it out and do it differently - but since i have my wires already custom made - i need to work with what i have - either way - this is what i ordered instead
http://www.bluesea.com/products/5191/MR ... _30_to_300
expresso wrote:this way i could use the wires i have already - i bet after all this i am going crazy about etc, - when the tech does it - he may not not even use it - and just piggy back it to the post with the original wiring already is fused etc, - i have a feeling thats what he will do - thats the way i was thinking from the start also -
expresso wrote:i was also told the charger which is fuses input and output with a 30 amp fuse also - will do the same thing - protect the cicurt and charger in the event of any short etc, - now i am not an electrican - not even close when it comes to wiring etc,
expresso wrote:all my infomation either comes from here and others who are in the field - i feel safe to say they all know better than i do - its done - i ordered it - and at least i have it in the event he wants to add it - turned out to be more than i expected but better to have if needed - i want this to get done the same day he brings the batteries - change them - connect it and thats it - hopefully
expresso wrote:if i didnt add this fuse and for some reason the charger fuse blows - i can just change that fuse in the charger - wont have to worry about taking chair apart to change a fuse in there - - reason is i wont be able to just take it apart to check the fuse i added - i would have to call the tech myself - kinda off the record thing to come and check it
robnnorthaustin wrote:Expresso, Thanks for the link! I just spent a few dollars with Del and they do have good prices. As to your statement that you are getting alot of different answers. I understand why. You can ask the same question more ways then anyone I've seen. It's obvious you are new and uncomfortable at this and most here have answered you in new ways as you keep asking the same questions. IE where you should attaach the charging cables to the battery. Even you answered your question twice!.....and then asked again LOL. If you don't want to buy a meter and learn "why" you attach a wire in a certain way or place then just find a good tech and then go in the other room when he is working on your scooter. If you ask him the same question over and over he might not want to use his precious time or your precious money to explain over and over.
paulgato wrote:Here's a link to an $8 multimeter from Amazon.com, and that's not even the cheapest, but it's still less than half the price of the fuse you just bought...(!)
http://www.amazon.com/INNOVA-3300-Hands ... A88RZDMKQ5
You don't need anything more special than this to check battery voltage, charger output voltage, etc. Or even something as simple as, lets say some piece of equipment stops working and you think it might be a blown fuse: do you go the trouble of identifying what kind of fuse it is and going and buying another just to check, or do you spend 30 seconds checking the fuse on the meter?
Expresso, you obviously WANT to understand more about the electrical systems you rely on, and with any cheap multimeter like this you can SEE what's going on, rather than just guessing and hoping for the best. I do recommend you get one.
if i could do what he does and know what he knows - i be doing the same thing hes doing - building his own chairs etc
as for me - i have learned alot but its never enough i am excited if i get my fast charger hookup done right -- even if i only use it when i get home when in the Red - at least i know i can get a good fast full charge in 3 hours at most
Users browsing this forum: Bing [Bot], Burgerman and 19 guests
