by Burgerman » 05 Mar 2014, 22:03
Well having had a few lockups and runaways with powerchairs and helis (carbon fibre and big batteries etc I really do recommend something with at least 2 remote EXTRA receivers.
Because 2.4ghz can be blocked by the chairs metalwork, rear canes, or even reflections from walls indoors etc. Move 1 degree, or 1 inch to the left, all works again.
This is a bit worrying with a heavy powerful chair. Or a helicopter. The receivers antenna MUST have line of sight (no carbon or metal tube etc) for reliable 100 percent solid control.
As such my Roboteq chair has 4 receivers. Including 1 high up in the backrest. Easy to do with a permanent installation. And one each side, as well as the main rx.
Now I have a "flight log" device. Plugs into the RC RX. I can drive a chair about the house and then look at how many frame losses, holds, etc each remote rx shows. The result of this shows me that 1 single RX isn't very safe! Even in line of sight. Slowly rotating the chair shows different remote rx getting frame losses etc as the chairs metalwork blocks the signal.
So even on my remote Omni plus device, that has to be compact I have:
1 main 10 channel RX.
3X remote receivers.
That's 4 total, located in different places, and in different "planes". In this way I can drive behind cars, anywhere in and around my street, and there's always at least ONE receiver that is showing 100 percent solid connection.
Some pics...
This picture shows the Omni sat on a black box.
The black box contains Woodys interface board, and a 10 channel (AR10000 RX) on DSMX channel hopping 2.4ghz. Its antenna is horizontal.
On the rear corner, nearest you is an extra receiver, 6 inches away from the internal one, with its antenna in a different plane (vertical)
- Attachments
- 1.jpg (91.1 KiB) Viewed 20686 times
