Re: PINNED - Plug & Play PGDT for Radio Control
Posted: 25 Sep 2018, 12:31
titanko wrote:Do I need to switch with the switch or the thing already automatically works both simultaneously in parallel.
How in this case the shift of the joystick affects the outputs of the Arduino?... Ummm What?
The Arduino feeds 'fake joystick voltages'
eg, Joystick is physically neutral but fake 'full speed' volts are fed to the outputs of the Joystick from the Arduino.
Yes both work at the same time in parallel ...ish, the reality of using the joystick and RC / Arduino to input two different directions (at the same time) will only end up in those vectors being added and interpreted by the controller in an unpredictable direction/speed.
