woodygb wrote:http://www.invacare.com/parts/archived_pdfs/4_Electronic_History.pdf
page 11 ?
... swap the motor leads over at the controller plug/socket ..if the R.H. motor error becomes L.H motor error....then you know it's the motor/wiring after the controller plug that is causing the problem...rather than a controller fault.and the controler is showing a fault on the rh motor wiring connector
woodygb wrote:... swap the motor leads over at the controller plug/socket ..if the R.H. motor error becomes L.H motor error....then you know it's the motor/wiring after the controller plug that is causing the problem...rather than a controller fault.and the controler is showing a fault on the rh motor wiring connector
woodygb wrote:http://www.ebay.co.uk/itm/261684890935?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D261684890935%26_rdc%3D1
That is fine as far as it goes...BUT ...you also need a joystick pod and the proprietary ( expensive ) cable to connect the two.
woodygb wrote:I'd not go with that Roboteq....but it's your choice.
For a quick/easy fix I'd suggest this VSi as it's an all in one controller and joystick.
http://www.ebay.co.uk/itm/spare-part-VS ... 27f1cdbe58
For a complete chair with a VSi controller ..but you take a risk as it's spares or repair ...
http://www.ebay.co.uk/itm/Wheeltech-Ene ... 1505249193
woodygb wrote:BTW ...the 3 pin plug is for a lights module ... ignore it.
woodygb wrote:Duke ...Should you wish to program the VSi just say and the board will advise / guide you
Users browsing this forum: daveonwheels and 57 guests
