Arduino controlled wheelchair
Postby gcebiker » 07 Aug 2019, 23:12
ex-Gooserider wrote:
Max71 wrote:Hi woody, I'm developing an app that can work as a command emulator for a motorized system. My aim is to make a wheelchair (of my mother) move independently in the home environment, as it is experiencing a period of great depression due to the impossibility of moving independently. The house is small and moving is difficult even for a young person, let alone an elderly person with reduced vision. <SNIP>
Massimo
While not directly related to how to do your project, the above bit makes me feel rather concerned - it is generally not considered safe or wise to do radio or other remote control / autonomous stuff with an OCCUPIED power chair, UNLESS the occupant has the mental and physical ability to at least trigger an emergency stop if something goes wrong - the factory control systems are designed and heavily tested to be both 'Fail-safe' and 'Safe-Fail' in that they are unlikely to fail, and if they do the chair stops moving (Generally the safest option)... Radio signals can be disrupted, and not all of our designs have been torture tested to ensure 'Safe-Fail' operation.... Driving your mother through a wall if something goes wrong is likely to leave her with worse problems than just depression... :problem: :( BE CAREFUL!
The safest way is that movement of the chair (post joystick input) are reduced to a 'stop' state if an obstacle was detected by some sort of sensor, eg ultrasonic / Lidar . Woody has videos of such an interface ...i think there and/or there are variations on the theme on YouTube.
gcebiker
Postby ex-Gooserider » 13 Aug 2019, 04:40
True that it would in theory be safer to have sensors to trigger a stop, but on the flip side every time you add more stuff to the code, you also add potential for unexpected glitches and bugs, so it can be a mixed bag for the benefit.... Arguably it might be better to have an independent safety circuit that just triggers an inhibit, but that also has pitfalls...
In addition sensors and so on can also themselves fail....
It is why firearms safety training both encourages the use of "safety's" and at the same time tells you NOT to rely on them.... Same deal...
Postby Irving » 13 Aug 2019, 11:47
@max71 While I applaud your thinking and determination this isn't something easily done. A colleague of mine runs a research project involving teams from UK and France looking at 'shared control' systems for wheelchairs - think of it like riding a horse; you tell it which way, it does the job of (mostly) avoiding obstacles etc. The problems and challenges are non-trivial - even getting obstacle detection to work reliably in a home environment with varying hard and soft surfaces/material etc is a challenge; what works well to avoid walls and steer down a 1.5m+ wide corridor is all but useless to steer through a 1m gap between a sofa and a coffee table for example. And they've tried everything from simple ultrasonics, laser scanners, lidar, millimetric radar, machine vision, etc, etc. No one sensor technology works reliably in all environments.
But don't let that stop you... maybe you'll be the one to crack it!
Postby gcebiker » 13 Aug 2019, 12:51
Irving wrote:@max71 While I applaud your thinking and determination this isn't something easily done. A colleague of mine runs a research project involving teams from UK and France looking at 'shared control' systems for wheelchairs - think of it like riding a horse; you tell it which way, it does the job of (mostly) avoiding obstacles etc. The problems and challenges are non-trivial - even getting obstacle detection to work reliably in a home environment with varying hard and soft surfaces/material etc is a challenge; what works well to avoid walls and steer down a 1.5m+ wide corridor is all but useless to steer through a 1m gap between a sofa and a coffee table for example. And they've tried everything from simple ultrasonics, laser scanners, lidar, millimetric radar, machine vision, etc, etc. No one sensor technology works reliably in all environments.
Cant be that insurmountable, its a maths / parabolic problem. Instead of the chair driving to the gap directly, drive to it so that it is going through square...or square ish.
When learning to drive we are taught to look in the distance and our brains will figure out the rest, its triangulation. The closer we focus the sharper the angles become and the more sever our driving/steering correction's are.
If distance sensors were on each side of a wheelchair, a narrow 'field of view' and mounted on servo's, directed by a lidar.
....maybe two sets on each side, left side measuring the distance the left side of the obstacle and the left side measuring the right side to the obstacle and visa versa.
Creating double triangles.
Surely its just a maths problem to get the 'base' of the quad triangles to equal each other. To fit squarely though a gap.... ?
gcebiker
Postby Burgerman » 13 Aug 2019, 13:02
JUST a mathematical problem?
The Mathematical Universe
NASA/JPL-Caltech/R. Kennicutt/SINGS
The history of mathematics is a history of humanity seeking to understand the universe. Therefore, many consider the holy grail of mathematics to be the same as that of physics: a theory of everything, a unified theory that explains all physical reality.
Math generally plays a vital role in any theory of everything, but contemporary cosmologist Max Tegmark even goes so far as to theorize that the universe itself is made of math. In his mathematical universe hypothesis, he proposes that math is indeed a human discovery and that the universe is essentially one gigantic mathematical object. In other words, mathematics no more describes the universe than atoms describe the objects they compose; rather math is the universe. Tegmark even goes so far as to predict that a mathematical proof for a theory of everything could eventually fit on a T-shirt.
More than 60 years earlier, however, Austrian mathematician Kurt Gödel put forth a theory that argues quite the opposite. Gödel's first incompleteness theorem concerns axioms, logical mathematical statements that we assume to be true but can't be proven with a mathematical proof. A simple example of this would be the axiom of equality (X = X). We assume this to be a true statement, but we can't actually back it up with a mathematical proof. Gödel's theorem states that any adequate axiomatizable theory is incomplete or inconsistent.
The implication, according to theoretical physicist and mathematician Freeman Dyson, is that mathematics is inexhaustible. No matter how many problems we solve, we'll inevitably encounter more unsolvable problems within the existing rules [source: Feferman]. This would also seem to rule out the potential for a theory of everything, but it still doesn't relegate the world of numbers to either human invention or human discovery.
Regardless, mathematics could stand as humanity's greatest invention. It composes a vital part of our neural architecture and continues to empower us beyond the mental limits we were born with, even as we struggle to fathom its limits.
Postby Irving » 13 Aug 2019, 15:04
The math is relatively easy.. deciding what and where the obstacles/gap are accurately, reliably and quickly enough whilst moving through it turns out to be quite tricky
Postby Max71 » 14 Aug 2019, 18:30
Hi Irving, first of all I thank you for the warning.
I agree with you that this project is simple in thinking but difficult to make it. What I think I do is, try. Various levels of redundant control, different types of visual and sensorial recognition, locking system for each electrical fault, many tests and I supervise myself with that nice red stop button on the robot. I don't know if I will succeed, but I try. :D :D
In the worst case scenario I will try to steal the google car project! :lol: :lol: :lol:
Max71
Postby Max71 » 14 Aug 2019, 18:51
At the moment my idea is to implement various layers of control. The first is only sensorial, to teach the robot to avoid obstacles, through a small ANN, there are many examples on the web that seem to work well. Having established this aspect, I will pass to the second level, the best navigation in tight environments. Yesterday I was discussing this with an engineer who was in charge of drone navigation for the army, he told me that it is very difficult but not impossible, and I believed it! :lol: :lol: :lol:
Max71
Postby Max71 » 14 Aug 2019, 19:06
Burgerman wrote:JUST a mathematical problem?
I do not exclude asking God for the solution. :lol: :lol:
Max71
Postby hatam1996 » 15 Nov 2019, 19:15
hi
can you give me diagram and code
More explanation plz
hatam1996
Postby gcebiker » 18 Nov 2019, 04:56
Hi if you search my posts there are a few hundred posts, i am sure among them (more to the end of the threads) you will find what you seek.
gcebiker
Postby hatam1996 » 19 Nov 2019, 11:30
gcebiker
thank you for replying
You did a great job
Just another question
Can I use Joystick Module
hatam1996
Postby woodygb » 19 Nov 2019, 11:36
Postby hatam1996 » 19 Nov 2019, 11:46
woodygb thanks
you are so cooooooooooool guys
hatam1996
Postby woodygb » 19 Nov 2019, 23:45
Yes ...but you will need to rewrite part of the Arduino sketch.
Postby hatam1996 » 21 Nov 2019, 21:23
Where to edit the code
I don't know ?
hatam1996
Postby hatam1996 » 21 Nov 2019, 21:27
CAN YOU GIVE ME sketch Modified code
hatam1996
Postby woodygb » 21 Nov 2019, 22:23
Can you make the control board?
This is NOT just an Arduino.
Not sure ...but there might be a sketch by gcebiker for a Blue tooth Arduino Nunchuck if you look thru the threads.
Postby hatam1996 » 22 Nov 2019, 00:45
Yes, I made it
But it didn't work
hatam1996
Postby woodygb » 22 Nov 2019, 12:25
Concentrate on getting that working as it is needed WITH any Arduino Sketch.
Postby gcebiker » 22 Nov 2019, 23:34
hatam1996 wrote:hi
I made control board
And used Joystick Module
But it didn't work
Please give me the code I want it to work with the joystick model
CAN YOU GIVE ME sketch Modified code PLZ
Hi Hatam, if you go to the thread posting.php?mode=reply&f=2&t=6503
You will find new versions of code that work better, if you post there you will have the most up to date information.
I have started working on it again, its summer here In Australia and I am getting ready for Squid season early in the new year.
I am now working on using the emulator to drive a Storm Arrow power chair with Brushless or 'GB' motors as Invacare calls them (Gearless Brushless)
The Emulator works with the POWER MODULE, it replaces the JOYSTICK MODULE.
gcebiker
Postby hatam1996 » 22 Nov 2019, 23:38
this my control board
hatam1996
Postby woodygb » 22 Nov 2019, 23:48
Do you have the original joystick module?
Postby hatam1996 » 23 Nov 2019, 00:03
yes i have
I have already asked for help with this problem on the site
viewtopic.php?f=2&t=9046
hatam1996
Postby gcebiker » 24 Nov 2019, 02:15
hatam1996 wrote:yes i have
Hi Hatam, i will reply on that thread.
Rebuilding a joystick is incredibly complicated.
Lets talk on the other thread about the faults you have with your current factory joystick.
We can try to help with that problem first.
Tony
gcebiker
Postby kaban » 19 Apr 2020, 12:55
Hello folks,
Does anyone know the baudrate of the CAN in a DX Controller?
I am working on getting a Invacare G50 controlled by a Arduino Nano.
Already got some telegrams out of it (100kBaud):
42 3 B0 81 21
42 3 1F FC 1C
42 6 B0 81 21 92 FF BF
42 3 FC 1C 1
42 3 B0 81 21
42 3 C2 50 B0
42 6 FF BF 1C B B0 81
42 3 2D 50 B0
42 3 48 10 1C
42 3 48 10 1C
42 6 A5 DE 1C B B0 81
42 6 C2 B0 81 27 20 89 //beginning to steer somewhere here
42 6 20 45 FF D8 50 B0
42 6 41 F2 1C B B0 81
42 6 45 F9 1C B B0 81
42 6 20 45 F5 1C B B0
42 6 41 EA 1C B B0 81
42 6 B0 81 23 20 45 F3
42 6 41 DB 1C B B0 81
But when sending one or many telegrams back to the Controller, nothing happens. I've tried it with many different tools but not every tool is working with their own code. (Tried tools with Lawicel (CAN232) protocoll and ASCII console output from Arduino. The console output from the arduino appears to be the most reliable way of reading but it's definetely not the most comfortable way of doing so.
With watching the Behavior of these telegrams for an hour and trying to understand which telegram does what I neither had luck.
So I went here to ask if someone has got information about the DX Bus..
Working with this:
-Arduino Nano
-MCP2515 + TJA1050 CAN-Shield (https://www.ebay.de/itm/MCP2515-CAN-Bus-Modul-TJA1050-Transceiver-5V-Arduino-Raspberry-Pi/253369172743?hash=item3afdfac307:g:Z4wAAOSw9tlb4ifz)
kaban
Postby kaban » 19 Apr 2020, 13:12
Telegram scheme:
ID Length Data
kaban
Postby woodygb » 19 Apr 2020, 15:41
RS485 is the coms protocol.
WheelchairDriver • View topic - Dynamic Controls Power chair, RC Boat trailer project
viewtopic.php?f=2&t=6503&start=300#p117806
Postby LROBBINS » 19 Apr 2020, 18:27
I think that the Shark is RS|485, but I'm pretty sure that the DX (& DX2) is a proprietary version of CAN.
Users browsing this forum: rover220 and 28 guests
