woodygb wrote:You need to replace the 7805 with a Tracopower TSR 1-2450 and feed it 24v.... the Traco is an All in One....so the caps can go.
http://au.element14.com/tracopower/tsr- ... dp/1696320
I think that there is a 10k resistor on the feed to D3 and the resistor value across A-B is 22k.
The SBH wire is pulled down to zero volts by 270 ohms in parallel with 22k ohms at the SPM and the SR (The 270 ohm terminations switch off when the bus voltages rise above 8V). This is the "recessive" state and it represents a 1. To transmit, modules pull the wire to 5V. This is the "dominant" state and represents a 0. Note that the transmitting circuit will not achieve 5V; 4V is more likely.
woodygb wrote:I drew this for myself sometime ago using your info..
sirmike wrote:1N4001 or equivalent for the diodes?
sirmike wrote:I was also thinking that it would be good to add some mounting holes off to the side out of the way of the shark bus connector.
Users browsing this forum: daveonwheels and 44 guests
