by JoeC » 03 Nov 2010, 18:14
I think even more importantly I would try not to let the Roboteq ever fail like that. The main failure mode that we're talking about is Mosfet failure, which is the result of bad wiring and pushing the controller to its electrical limits of voltage and current.
The way I'd minimize chance of failure would be to stick with 36 volts, and limit current to something more conservative like 120 amps. I don't think you'll miss the last 30 amps unless you're in deep soft terrain, and the more headroom you give the thing the less chance it will fail. The other thing to do is to be careful with wiring. Keep lengths short, twist conductor pairs, don't run signal close to power. Ground pins that should be grounded, and do everything by the book.
The power and control that comes from even 100 amps from both motors that doesn't fade at all until a jogging pace is a fairly useful thing- even for a large guy such as yourself.
Another possibility if you're worried about more than just mosfet failure would be to rig an E-stop button as a digital input to the controller. That's configurable, and will immediately kill the output when activated. That would be easy enough to put near the joystick, and would be useful if something went wrong with your joystick trim resistors, or you had some other input error.
