R-Net PC Programmer OEM
Re: R-Net PC Programmer OEM
Postby rover220 » 01 Apr 2021, 12:13
Burgerman wrote:Also understand that there are TWO different CJSM2 joysticks. One has BT built in and both have infra red control. Both look the same. The BT version is more expensive. I have 4 in total. Two spares in a box, and two on chairs. Only one has BT.
You can also get BT modules that plug into a bus cable. And you can have two if you want. But again not cheap and an add on option. So unless you specified a BT joystick, or a BT module then you likely dont have BT. You DO definitely have IR or infra red though on all CJSM2. That can control any infra red device like light switches, TVs, set top boxes, etc.
Ok, I see. But, my order form said CJSM2-BT, so it has IR etc., built in, right?
Yes that has both BT and IR.
Omni 2 gets Bluetooth as standard also.
You can no longer buy the stand alone Bluetooth modules new, used only.
Postby Solodown » 01 Apr 2021, 12:15
steves1977uk wrote:Hmm, Permobil chairs have their own OEM software which sounds like that's what you need. Trouble is it's very hard to get hold of. :thumbdown:
Unless you can get the original settings file from Permobil, you're pretty much screwed due to their proprietary firmware/software.
i have Setup_rnet_programmer_Dealer_Permobil_6_1_5
Solodown
Postby Burgerman » 01 Apr 2021, 12:46
Not any more. Check PM!
Postby expresso » 01 Apr 2021, 16:31
i have to check my order form also -
Postby Fusiongoat » 02 Apr 2021, 06:41
I realized that I have generic, but also need Sunrise. Can I get help with this? Thanks
Fusiongoat
Postby Burgerman » 02 Apr 2021, 11:26
Check PM
Postby Roadrunner » 28 Apr 2021, 10:54
Burgerman wrote:Not any more. Check PM!
Permobil OEM ??
That would be very interesting.
Roadrunner
Postby Burgerman » 28 Apr 2021, 11:50
Permobil no sorry. Permobil go out of their way to do their own thing, and use "compatible" R-net seating, gyro and stability modules and even cut down cheap versions of the CJSM2 joystick with a duller smaller screen with 2 buttons missing. So you are FORCED to rely on them due to very poor generic R-Net compatibility. They also make their own switch box that does not just connect to the r-net bus like the switch it ones, (so easily programmed with the R-net programmer, but it connects to their own large box of seating stuff... That even they seem unable to fix. They also use the proper R-net CJSM2 on some chairs too that have incompatible firmware.
So you might be lucky and might not. On some settings and be missing others. If you use the sunrise or generic OEM software you may be able to adjust some of the options. Others will be missing. And sometimes it wont let you load a settings profile or make changes at all. So basically dont buy permobil unless you like relying on others that dont seem able to fix their own system. And especially want oem access for youself. Personaly its a deal breaker for me. I wouldnt buy pride, or permobil for the exact same reasons.
Postby FelipeOliveira » 18 May 2021, 08:15
Good Morning
I need an Rnet dongle OEM version!
Can anyone indicate? Shipping to Brazil
FelipeOliveira
Postby Burgerman » 18 May 2021, 09:08
See PM.
Postby Furio » 23 May 2021, 08:27
Hi all,
Could anyone please give a link to sunrise r-net OEM pc programmer.Thank you.
Furio
Postby Burgerman » 23 May 2021, 08:30
Software?
See PM.
Postby Furio » 23 May 2021, 14:17
Hi BM,
Thank you very much. :thumbup:
Furio
Postby steves1977uk » 23 May 2021, 15:05
FelipeOliveira wrote:Good Morning
If you're ordering from PSS, make sure they're sending you a boxed new one. Otherwise say you'll go through Paypal/Credit card for a full refund which they don't want you to do. I got 50% off because the dongle had been used and is all scuffed on the back of it.
Postby Burgerman » 23 May 2021, 16:58
If you give them grief or threaten to do anything they will just refuse to supply. Too much trouble/risk.
Postby rover220 » 23 May 2021, 17:38
Burgerman wrote:If you give them grief or threaten to do anything they will just refuse to supply. Too much trouble/risk.
Agreed, I assume the scratched dongle mentioned still functions as intended?
Postby steves1977uk » 23 May 2021, 22:45
Just did a quick test yesterday, the dongle's red power LED lit up when plugged into USB hub and I get the green LED come on when I run the programming software. Haven't tried plugging it into one of my chairs yet but will be doing that on Tuesday when Melissa is here. :thumbup:
Postby rover220 » 24 May 2021, 05:25
steves1977uk wrote:Just did a quick test yesterday, the dongle's red power LED lit up when plugged into USB hub and I get the green LED come on when I run the programming software. Haven't tried plugging it into one of my chairs yet but will be doing that on Tuesday when Melissa is here. :thumbup:
sounds like all is good then :thumbup:
Postby steves1977uk » 25 May 2021, 23:53
Dongle works fine, used it today to tweak my Dietz chair setup. :thumbup:
Postby FelipeOliveira » 29 May 2021, 08:08
Burgerman wrote:See PM.
Thanks BM .
FelipeOliveira
Postby Swan T.W. » 31 May 2021, 17:07
Anybody use the hand held programmer? I like to change settings on the move. What settings, if any am I missing out on if I use the R-net hand held programmer?
Swan T.W.
Postby Burgerman » 31 May 2021, 17:59
There isnt one is there?
Only the service tool?
What are you missing out on? All the OEM settings. But if you use the OEM tool to enable OBP you have all the dealer settings built into to joystick.
Postby rover220 » 31 May 2021, 18:01
There's the old dealer DTT or the newer wireless programmer that's a half way house between dealer and oem.
Postby Burgerman » 31 May 2021, 18:41
The wireless one is 'A' as in dealer isnt it?
Postby rover220 » 31 May 2021, 19:46
Burgerman wrote:The wireless one is 'A' as in dealer isnt it?
It's above dealer level but not to oem level.
Postby Burgerman » 31 May 2021, 20:11
Is there a list of what it can do extra anywhere?
If it can remove the abs walls and tweak compensation it might beall most users will ever need.
Postby Swan T.W. » 31 May 2021, 21:38
Burgerman wrote:Is there a list of what it can do extra anywhere?
I couldn't find one. That's why I asked the knowledgeable people on here.
Swan T.W.
Postby Burgerman » 31 May 2021, 22:09
Well I was told its the same as a dealer dongle. So who knows.
Postby kajapa » 11 Jun 2021, 14:33
Hi.
At first, sorry for my English, I'm from Poland.
My wheelchair is meyra optimus 2 with r-net cjsm BT.
I have a problem with too sensitivity steering servo. Meyra servis send me program "Setup_OEM_Sunrise_EU_6_3_0" version, but there is no option to change the steering servo settings. I need the OEM version that will change settings of the steering sensitivity.
kajapa
Postby Dan » 11 Jun 2021, 19:36
kajapa wrote:Hi.
Have you got the programming dongle?
Some of this thread may be a little help.
https://www.wheelchairdriver.com/board/ ... php?t=4925
Dan
Users browsing this forum: LROBBINS and 102 guests
