Burgerman wrote:At that price I would rewind them or throw them away. You don't really need them, I have an old chair with brakes thrown away...
woodygb wrote:The controller needs to see a resistance ... replace your brake with a 24v relay coil.
e.g.
http://autoelectricalpartsuk.co.uk/prod ... wwodasAEEw
woodygb wrote:NOTE ...When replacing the brake with a resistance the whole brake assembly must be REMOVED from the motor.
Park Brake Testing Value: Park Brake Testing
Driving - The R-series checks the parkbrake for open circuit faults before and during driving.
Pre-Drive - The R-series checks the parkbrake for open circuit before driving, but not during driving. Use this option when the test during driving is very noisy and/or incorrect faults are generated.
None - The R-series does not check the parkbrake for open circuit faults at all.
This option allows the R-series to be used without an electric parkbrake.
Note: For safety reasons, the R-series always tests for short circuit faults. This can't be disabled.
Warning:
For safety reasons, do not use 'None' if the scooter has an electric parkbrake.
FelipeOliveira wrote:woodygb wrote:NOTE ...When replacing the brake with a resistance the whole brake assembly must be REMOVED from the motor.
I have frequently come across a situation with a scooter ( CTL HS-559) with a 24v 16.8w brake, with a dynamic controller, in one month I received 3 with the same problem!
Is there anything that can be done to prevent it?
woodygb wrote:Questions.
Had the brake coils actually failed ( burnt out ) ?
Had the controller been setup /wired up to give the brake coil the correct voltage ?
woodygb wrote:The brakes seem to have overheated and then shorted out .... is there a possibilityu that they where 12v rated instead of 24v?
Users browsing this forum: acid_coke, shirley_hkg and 26 guests
