:mrgreen: Wish I could use my hands to build stuff.
You can use others hands as I mostly have to do. You learn to instruct!
Burgerman wrote:Lights. Very hard to photograph. The yellow ones will be red LED when they arrive. So all will be red.
They are lots brighter than this seems to show. Sunglasses required!
Evening, room lights...
Daylight...
Burgerman wrote:http://www.ebay.co.uk/itm/361442455527?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/380891608375? ... EBIDX%3AIT
http://www.ebay.co.uk/itm/121215117549? ... EBIDX%3AIT
some use different! Take a look first.
Thermal switch was out of my pile of bits. Came from an old power supply. http://www.renge-components.com/photo/p ... mostat.jpg Like this. 40C woulds be better.
Burgerman wrote:The chip is fixed with epoxy inside the case, the wires go in series with the computer fan. And a resistor to give approx 12V and connected permanantly to the 24V supply.
SteveO wrote:Burgerman wrote:The chip is fixed with epoxy inside the case, the wires go in series with the computer fan. And a resistor to give approx 12V and connected permanantly to the 24V supply.
So I epoxy the switch directly to the inside of the case near the mossfets and run two wires to the positive wire on the fan, obviously splicing into the pos wire. The connect the fan wire direct to the batteries via a resistor? Or even just to one of the batteries? Sorry to be a pain in the ass but I don't want to get it wrong.
Thanks John
Burgerman wrote:Next job. Making the powerchair RELIABLE!
Stock powerchair motor couplings, on most powerchair motors, or rubber cush drives if you prefer, fail with monotonous regularity. As soon as you fit decent low resistance batteries (throw away those gels), fit decent wiring, and program the chair to turn, stop, and go.
I have a draw full of these failed ones. From 3 different motor manufacturers. It feels like a gearbox failure, but in reality its a £2 part... Most are similar. What happens is that suddenly you put some real torque through them. And the outside case splits, jams under load as it expands.
I fix these now BEFORE they can fail.
The problem: (Good one on the right...)
Burgerman wrote: So a 7.0 mph chair now goes 8.04mph
Users browsing this forum: Burgerman, DrewDigital, woodygb and 148 guests
