stevelawiw wrote:I wonder if there are more in the latest version that are installed on the chair John had for a while, the last time I looked I couldn't find a part number for them to find out how much they would rush you for a pair I bet they'd be pricey.
Allegedly the Storm4 have more torque than the Storm3.
Burgerman wrote:Allegedly the Storm4 have more torque than the Storm3.
And about 1/3rd that of a typical 4 pole AT STALL and around the same once rolling slowly. StraNge behaviour. I measured 190A on a battery cable repeatedly when doing a zero turn with an empty chair. It lasts around 1 second, then the current and the torque fall away to aroung 1 fifth of that. And the motor gets very warm if you try to go left/right.
Its a terrible solution. It needs gearing. Because in an attempt to get some level of starting torque they literally murder the batteries. In the same circumstances a typical 20A of current is seen on a geared brushed chair.
On a run, the current is under 2.5A with both motors flat out! The exact opposite. Super efficient once rolling.
Burgerman wrote:Theres another. Some have a deeper/shallower wheel rim, and the position of the ridge for the tyre on the drum is different. So... You can use the wrong parts to give a wider tyre J section. Theres around 10mm difference. Not sure which way round it is but I have 2 sets of motors that look very similar, other than this. One set came from the mid drive chair. So you can have a slightly wider or narrower track.
Irving wrote:There was an earlier version for Storm 2G/Arrow/Torque chairs c 1998/9 which had a hub rather than the 8" rim. I can't find a part # for them, but I doubt you'd want them anyway.
The difference between the TDX motors is the later ones have a slightly wider rim increasing chair width by 0.75".
GB motors were options on TDX - TDX4 & standard on TDX5
My first chair after I broke my neck was an old Arrow 2gt (or some similar nomenclature) with the gb motors. Very efficient and fast for a stock powerchair. Unfortunately, it was very weak. Near 0 starting torque. Someone could put their foot in front of the tire and the controller would max out without the chair moving. Stop on a ramp and you had to back down. Once it was rolling it did good. It would not wheelie from a start but would if you were rolling slowly and gave full throttle.
shirley_hkg wrote:Wife and I went to collect 2 boxes of total 32 EVE-LF105 cells
Scooterman wrote:Shirley - right at the end of the video there's a car parked in the way. Should he not be parked there?
Scooterman wrote:shirley_hkg wrote:Wife and I went to collect 2 boxes of total 32 EVE-LF105 cells
Are they the ones with M4 thread?
Are lugs available that can accommodate a large diameter cable but still have only an M4 bolt clearance hole?
The reason I ask is usually the larger the cable size the bigger the lug bolt clearance hole?
Users browsing this forum: No registered users and 79 guests
