She can have the chair fine tuned to her driving style - i understand how you wont like it and she may not like it either till its fine tuned to her driving habits and once its done - she wont have to keep touching it etc, -
Burgerman wrote:The seat thing is due to anti tip tests to pass regulations to stop it going over backwards in certain situations. It results in every single rear drive chair on the market being a pig of a thing to drive/turn, use. And eat batteries. So whatever4 rear drive chair she gets will be the same and will either stay like that, or require some user action to correct.
The programming thing can be overcome on any chair that is not pride one way or another...
It also only has Curtiss Wright VRII controllers rated upto 90A.SWalkusz wrote:even a centre mounted footboard option, lol - Not sure about the controller, though? I reckon the voucher should be worth £2k + a nominal amount for self maintenance with any luck + seating option maybe over and above, fingers crossed. We could be looking at acquiring it all for only a £1k contribution, perfect. Cheers
SWalkusz wrote:It also only has Curtiss Wright VRII controllers rated upto 90A.SWalkusz wrote:even a centre mounted footboard option, lol - Not sure about the controller, though? I reckon the voucher should be worth £2k + a nominal amount for self maintenance with any luck + seating option maybe over and above, fingers crossed. We could be looking at acquiring it all for only a £1k contribution, perfect. Cheers
looks like a pretty standard RWD / front pivoting caster setup to me - so whats special?The Airwheel H3’s omni-directional wheel design enables it to steer at 360°.
Wheel-less wrote:I only have the very limited Sirocco. This is a size issue as I live in a basement flat, down 10 steps. The wheelchair lift that I have is the smallest and the platform comes down to the small area in front of my door so I can only have a wheelchair that is close to a manual wheelchair size. Anything much larger and I would not be able to open my door.
The range on the Sirocco is rubbish. I know the stated range on electric chairs is shockingly inaccurate. But some makes may be "less inaccurate" than others...In the case of my Sirocco, the range for new batteries tends to be around a FIFTH to a TENTH of the stated range of 25 miles; So the best range I've ever gotten was around 5 miles for NEW batteries, which decreases down to around a sixteenth of a mile (and losing one of my two green lights) when the batteries get old.
This is a problem because I live in London, and NOTHING is that close. Living in the King's Cross area, I can't even get to the West of London except by paying for a cab.
I'm wondering, therefore, if anyone can suggest a small chair with better (actual) range that might take, say, 75ah batteries? I will have to get one second hand as my pension would have to be saved until a few decades after my death in order to afford a new one! My old Sirocco is making noises that suggest it is not long for this world, and I haven't a clue about what sort might be more reliable and increase my range.
I am a luddite and technophobe, so do not waste your technical expertise on me. It truly would be like trying to make a silk purse from a sow's ear.
Oh, and Burgerman, I love/hate looking at your chairs and reading about their range and speed! Oh, Jealousy! But thank you for this forum!!!!!
But you would have to make daily trips to discharge the batteries sufficiently to get them maintained properly.
Burgerman wrote:What idiot told you that?
YesIs it a good idea to keep the AGM batteries on charge when not moving and pull the charger out before it has fully recharged.
Wayne told me, the wheelchair services Engineer
even if what said is true, how can my NHS XTR2 HD never do more than about a mile and a half with 50Ah Invacare (MKUltras with invacare sticker plastered over the top). On constant charge with the Invacare Opticharge
