i have SB50 connectors i can use already - but i am confused also with the PL8 - in the picture it shows the wires coming from the rear - the plug there is not a SB50 etc, - what do i do with those wires with that Plug ?
are those the wires that need to be plugged into a PSU ?
Burgerman wrote:http://www.store.revolectrix.com/Cellpro-PowerLab-Stackable-40A-Safety-Banana-Plug-Cable?ext=F get 1
http://www.store.revolectrix.com/Produc ... t-II/FUIM3 get 1
http://www.store.revolectrix.com/Produc ... 3-1m-BLACK get 1
http://www.store.revolectrix.com/Produc ... G12-1m-RED get 1
http://www.store.revolectrix.com/Cellpr ... able?ext=F get 2
http://www.store.revolectrix.com/Produc ... Lab-8_1429
Get 1 and fit Anderson connector. And you will need either a car thats running, or a powerful power supply to run this. Its small and light, but 1340 watts!
You need around 40 to 50A and around 24 to 30 volts to power it at full power.
Then download the PC Software and click advanced, and study it!
And CAREFULLY watch, read etc here, http://www.revolectrix.com/CCS_Tour.htm
Burgerman wrote:For home use, better to get something like mine.
http://www.ebay.co.uk/itm/DIGIMESS-SM30 ... xykMpTIidV
Ignore that price. I have two. I paid 190 and 210 for them on eBay. They are bomb proof, and are smooth accurate and reliable. And because they are adjustable can charge lead batteries directly at 40A. Just set 28.2V, or 28.8V and 40A and plug in. Very rapid recharge! I have 2 in parallel so can charge at 80 Amps!
http://www.hobbyexpress.com/ec3_device_ ... 5_prd1.htm
Would this cable work to connect to the PL8 and to the PSU ? i wont have to cut the cable on the PL8 to add a SB50 on it - i worry if i make mistake and then have to keep cutting it shorter to try again etc, -
what do you think -
expresso wrote:the cost is too much - - only ones i see are in the 800 dollars range - you must have found yours used ? at that price -
either way - this is overkill for me - i just want a simple unit - with power switch - i seen them i just forgot the name - it had one 50 amp to charge from or 60amp and 3 10 amp plugs also -
i dont trust used - not with my luck -
LROBBINS wrote:Careful when shopping for a power supply - there are many out there that can't handle both European (220V) and U.S. (110V) input. It you get a 220V unit and try to use it on 110, it won't work. If you do the opposite, it may well be damaged. If you expect to be traveling with it, best to get one that takes both supply voltages (if you can find one).
Burgerman wrote:You turn it up to max on Amps, and volts, and forget it.http://www.hobbyexpress.com/ec3_device_ ... 5_prd1.htm
what do you think -
That will melt at 20A and the charger can pull 50. You cannot connect with 4mm banana plugs... And its EC3 instead of EC5 which is a massively different size.
http://www.mastechpowersupply.com/volte ... input.html
Ok - this is why i need to know first - looks the same - didnt realize its different - it says handles up to 60 amp -
they dont have a connector from the PL8 power leads to Bananas that i can just plug into this unit ? or any other that takes the same plugs
steves1977uk wrote:http://www.ebay.com/itm/Power-Supply-to-EC5-Cable-/301127619450?hash=item461c9ad37a:g:f2kAAOSwT5tWJoQm EC5 plug to PSU for PL8
http://www.ebay.com/itm/Mastech-HY3050EX-DC-Power-Supply-Over-Voltage-Current-Protection-30V-50A-1500W-/361474510498?hash=item54298f4ea2:g:25YAAOSwGotWlWnq PSU, a little overkill for the PL8 but good qualty.
Actually its exactly correct. But looks rather 2nd hand... And has double glazing!
i think the links i found that i posted for $150 for a new one - its 75amp - 2400 watts - way more that i ever need - they are in the states - i will call them next week to make sure its new etc, and how it works - to be sure
Users browsing this forum: Bing [Bot], DrewDigital and 45 guests
