expresso wrote:thanks - its Neg. then - or i leave it alone - chair will be Off at home when being charged - not being used - - so just a small wire connecting both pins will do it ? nothing fancy or special
Correct - that third pin is just a data signal, so it doesn't carry any noticeable current... In normal use with the plug disconnected, there is a 'pull-up' in the joystick pod that brings the pin high and enables the chair. When you plug in a connector wired to disable the chair, the connection between ground and the third pin pulls it low, which is the disable signal. If you hook up a programmer, (cable or hand-held) it puts a data signal on the pin which can be read and processed by the microprocessor in the pod...
As BM said, it's optional to connect it or not, and he doesn't... However if you are subject to the occasional 'brain fart' having it connected can save you the embarrassment of trying to drive off with the charger attached....
I've actually had another thought occur to me - that might be a significant concern if doing a lithium pack / hobby charger setup... Obviously you don't want anyone attempting to charge the chair with a standard mobility brick charger via the XLR plug, as that would mean you didn't have balancing and thus risk pack damage... So how would we make it impossible for some well meaning but clueless person to hook up that evil mobility brick????
Labels and possibly even taping over the plug offer only marginal protection, as they don't stop the non-readers or determinedly stupid....
Taking the plug out (or disconnecting it) isn't the answer as we still need the plug for programming...
Next option would be possibly cutting the 24V line inside the pod, but I know that all the programming options need the ground wire for reference. I'm not sure about the USB cable, but I suspect that the hand held programmers and the factory serial cable would also need the +24V line for power (where else would they get it?) So that doesn't work either...
What I suspect might work, would be to put a medium size (1-2W) power diode in the 24V line - that would allow you to still have 24V (minus a diode drop) at the plug, and thus provide programmer power, but block the ability of a charger to supply 24V TO the batteries...
Any thoughts on this???
