Videos - Rides
Re: Videos - Rides
Postby Burgerman » 26 Jun 2017, 09:40
When you live in a country where it rains every day green is not a problem! Everywhere is green.
But the rain is then a problem...
Re: Videos - Rides
Postby LROBBINS » 26 Jun 2017, 10:03
Snaker,
Except for the lack of cars, that looks very similar to the roads near my home south of Siena, Italy. It would not be save to drive a WC along a road like that here amidst the drivers who think they belong in Formula 1. The only other difference is that we have had a month of temps in the mid 30's with no significant rain, so here it is less green. Indeed, the drought throughout Italy has reached a severe level (except where thunderstorms arrived in the last couple days and caused flash flooding as the ground is too hard-baked to absorb well). This is when the wine grapes should be plumping up, so I suspect that this Fall's vendemia is going to be disappointing. Excellent quality because of high sugar concentration, but much reduced quantity.
Re: Videos - Rides
Postby Burgerman » 26 Jun 2017, 13:24
Yes, italy is very green in parts. I did italy on 2 wheels years ago. With some drivers that were as mad as I was! I quite liked it. Driving rules and speed limits were advisory. As were traffic lights. 25 years ago on a nitrous injected Suzuki 1100.
Re: Videos - Rides
Postby snaker » 27 Jun 2017, 02:27
The scene in the video is a mountain and also a natural border between Viet-Laos. This mountain blocks the humid wind flows from the sea, all humidity stays on Laos side. So on the same time, it might be pouring down on Laos side but dry hot 40oC on Vietnam side. Plant in tropical jungles adapts well with the weather, it can be green even in the dry season.
Re: Videos - Rides
Postby Burgerman » 27 Jun 2017, 08:15
We have something similar in the UK's Lake District. Its all mountains. As you arrive, they allocate you a personal rain cloud. It follows you closely wherever you go at about 500 feet. And it never stops. :(
Re: Videos - Rides
Postby Mind The Gap » 28 Jun 2017, 09:04
Hi all
Another little video taken in Beckenham Place Park. The Clock house was a major part of the park until it got burnt down.
http://www.sydenhamsociety.com/2011/07/ ... d-by-fire/.
Was going past the other day and noticed that the gates were open and popped in for a quick look around.
As for the quality of some videos that's me being new to DaVinci Resolve and Luts with the added complication of too many Stellas :?
https://youtu.be/zLjBHdjsjS8
Regards, Paul
Mind The Gap
Re: Videos - Rides
Postby Mind The Gap » 04 Jul 2017, 08:13
Hi All
A video from Beckenham place park to Bromley hill using a gopro hero 5 set to 4K attached to a Feiyu tech G5 gimbal with an extension pole.
Was able to keep the camera 2 to 3 inches above the floor for some interesting views.
youtu.be/SzFlyo0kF6s
Regards Paul
Mind The Gap
Re: Videos - Rides
Postby expresso » 04 Jul 2017, 14:52
nice camera - video comes out nice - i have a issue now with one chair - the new tires i have make road noise and my camera is picking it up - dosnt sound good - havnt a clue how to get rid of the noise - guess i am stuck with it - just have to mute my videos when i use that chair
Quickie P222se - 60Ah ADD ON
Quickie 636 - 200ah LifePo4
Bounder Plus - 180Ah LifePo4
Re: Videos - Rides
Postby Mind The Gap » 04 Jul 2017, 18:14
Hi Expresso
expresso wrote:nice camera - video comes out nice - i have a issue now with one chair - the new tires i have make road noise and my camera is picking it up - dosnt sound good - havnt a clue how to get rid of the noise - guess i am stuck with it - just have to mute my videos when i use that chair
I located the microphone points on the camera and put a double layer of cellotape over them.
New video bit like last one, but of flower gardens with added music.
youtu.be/lVRh5mPM1rk
Regards Paul
Mind The Gap
Re: Videos - Rides
Postby expresso » 04 Jul 2017, 18:17
good idea - didnt think of that - i may have to get another camera - one for each chair - it only makes the sounds on one chair - the other you get the motor sounds - but not as bad - i have to give that a try - thanks
Re: Videos - Rides
Postby Gnomatic » 04 Jul 2017, 20:43
Mind The Gap wrote:I located the microphone points on the camera and put a double layer of cellotape over them.
Regards Paul
Do you have your camera mounted as well?
Re: Videos - Rides
Postby Mind The Gap » 05 Jul 2017, 08:56
Hi Gnomatic
Hero three mounted under front of armrest, Hero 5 was free hand till I can work out a quick release system for it.
Regards Paul
Mind The Gap
Re: Videos - Rides
Postby Burgerman » 05 Jul 2017, 09:16
U tube vids...
I added a button! Look at the tabs above. Push button.
You get this:
Code: Select all
[YouTube] YOUR STRING GOES HERE [/YouTube]
Look at U tube URL in the address bar. At the end theres a short string of numbers. After the = sign.
Code: Select all
https://www.youtube.com/watch?v=i9m4H9F4-ng
The part you need is the i9m4H9F4-ng
Re: Videos - Rides
Postby Mind The Gap » 06 Jul 2017, 07:03
Burgerman wrote:U tube vids...
You get this:
Code: Select all
Code: Select all
Hi BM
Can't find button you are referring to.
Regards Paul
Mind The Gap
Re: Videos - Rides
Postby Burgerman » 06 Jul 2017, 07:54
Re: Videos - Rides
Postby Mind The Gap » 08 Jul 2017, 10:14
Hi Expresso
https://www.youtube.com/watch?v=lVRh5mPM1rk
Regards Paul
Mind The Gap
Re: Videos - Rides
Postby Mind The Gap » 08 Jul 2017, 10:16
Hi All
Regards Paul
Mind The Gap
Re: Videos - Rides
Postby Burgerman » 08 Jul 2017, 10:42
I turned the link to a vid for you.
download/file.php?id=6773&mode=view
See above!
How is it stabilized?
Built into cam? A mount? Via software afterwards?
What / how is it mounted?
Re: Videos - Rides
Postby expresso » 08 Jul 2017, 14:57
i like the view you get with your camera where ever you have it mounted - can you show some details - where you have it - and how etc,
Re: Videos - Rides
Postby Mind The Gap » 10 Jul 2017, 12:00
Hi all,
In answer to some of your questions about camera positions and such, I have made a video to demonstrate.
https://www.youtube.com/edit?o=U&video_id=oz_v6pcWpI0
My Son in law thought it was funny to make another version with a different start and ending to wind the Wife up.
https://www.youtube.com/edit?o=U&video_id=_VR5CSQ9RV8
Regards,
Paul.
Mind The Gap
Re: Videos - Rides
Postby Burgerman » 10 Jul 2017, 14:36
Re: Videos - Rides
Postby Burgerman » 10 Jul 2017, 14:37
Re: Videos - Rides
Postby Burgerman » 10 Jul 2017, 14:41
Ah. A gimble.
I used the YouTube button, and the _VR5CSQ9RV8 code.
Re: Videos - Rides
Postby snaker » 11 Jul 2017, 08:01
This place is like another version of the Stonehenge in UK. Do you recognize where it is?
https://youtu.be/wpPQkbau9wk
Re: Videos - Rides
Postby Burgerman » 11 Jul 2017, 09:31
Those are public toilets from many years ago.
Re: Videos - Rides
Postby snaker » 11 Jul 2017, 09:46
Burgerman wrote:Those are public toilets from many years ago.
Of course not. In fact they are much more mysteric, much more interesting than the Stonehenge.
Re: Videos - Rides
Postby Burgerman » 11 Jul 2017, 10:16
It was humour! :D
Was visualizing many people sat on them all, with a toilet roll. And a huge line waiting.
Re: Videos - Rides
Postby LROBBINS » 11 Jul 2017, 10:41
Re: Videos - Rides
Postby Burgerman » 11 Jul 2017, 11:14
Still think my explanation was better 8-)
Re: Videos - Rides
Postby snaker » 12 Jul 2017, 01:37
Yes, it is. I heard a guy wants to rename this pretty place to "the plain of ... toilets" :mrgreen:
Users browsing this forum: clairc, pferrie, rover220, shirley_hkg, woodygb and 138 guests
