hobie1dog wrote:I want to proceed with getting wider casters to accommodate the 3.00-4 tires John uses, but cannot find any, so I'm not going to buy the tires and wheels until I find some. The ones on EBay got sold quickly.
hobie1dog wrote:No, I have the S636 which has the narrow fork casters which are only 2.6 inches internal width with the stock 2.00x50 gray tires on it, so there's no way a 3 inch wide tire will fit.
expresso wrote:hobie1dog wrote:No, I have the S636 which has the narrow fork casters which are only 2.6 inches internal width with the stock 2.00x50 gray tires on it, so there's no way a 3 inch wide tire will fit.
they wont - but you need to get the larger forks - rims and then the tires - you can find the forks on Ebay most times - you can reuse the same bolts etc,
hobie1dog wrote:The same guy has a set of P–220 forks on there now but I don't know if they are the proper size for my S636
http://www.ebay.com/itm/Front-Forks-for ... 0290.m3507
Burgerman wrote:Why do you merican persevere with old fractional measurements/sizes? We scrapped that generations ago. Its so complicated.
For what its worth, 5/16 is 7.9375 Or damned near 8mm. So close that its just 0.06 of 1 mm different. A cigarette paper or less. Which for a bolt is close enough. For a bearing not so much...
hobie1dog wrote:Quickie wants $8.25 for a 5/16-24 axle bolt 4 3/4" long
hobie1dog wrote:After searching around it seems like a 4 3/4" long bolt is pretty rare. But a 5" bolt should work fine.
Burgerman wrote:Non of you guys evenr cut a bolt? Screw nut on first. Put in vice (the bolt head and the nut) cut off 1/4 inch. File the sharp edges. Unscrew nut...
hobie1dog wrote:Beautiful color vise
I looked at the scooter wheel/tire/tube assembly on EBay and it states that the axle size is 10mm (3/8"), so I would have to drill out the Quickie forks from 5/16".
http://www.ebay.com/itm/Razor-Pocket-Ro ... 1438.l2649
expresso wrote:hobie1dog wrote:Beautiful color vise
unless your set on getting new rims also - you can use the stock sunrise quickie rims they are plastic two pieace and this size tire fits it fine - then you wont have to drill anything - -
expresso wrote:i wonder if using this Rim tire setup on a quickie chair - instead of trying to drill new holes on the fork for the 10mm size - would it be possable to just change out the bearings on this rim tire combo for the correct size bolt and leave the forks alone ?
https://www.ebay.com/itm/Razor-Pocket-R ... Ciid%253A1
also on the stock rim - there is another sleave that goes thur the bearings which the 5/16 bolt slides in between -
maybe you can still use the stock bolt but without the sleave ? or change out just the bearings and use the stock sleave and bolt -
https://www.quickie-wheelchairs.com/rep ... caster-rim
number 9 - but this all comes in a set - so not cost effective -
of up find a pair on ebay - larger forks - with tires rims etc, - dont worry about the condition of the tires - all you want is the fork - and rim - should have everything you need -
Users browsing this forum: DrewDigital and 143 guests
