Pride Pursuit XL 36V
Postby Scollard » 18 Aug 2016, 21:04
Pride now makes a 36V model of my scooter.
My question to the experts out there; Would the controller and motor be the same? Is this just a faster scooter? And, if so, can I just rewire my Li pack to 12S or 14S and gain the speed?
A scooter is much simpler to control than your chairs. I have a circular pot. to set the speed and then it's just a matter of pulling a lever for forward or backwards. No complicated turn ratios, acceleration settings, etc.
Scollard
Re: Pride Pursuit XL 36V
Postby Burgerman » 18 Aug 2016, 21:16
The motor may well be the same. The controller will be different though most likely. If you look at the spec for yours you will likely see a max voltage of 32 to 35V so as to allow for charging/regeneration pulses on a 24v system.
Postby flagman1776 » 18 Aug 2016, 21:26
I think the Pursuit replaced the Wrangler model I have. If one must replace the Wrangler motors, you must replace both with the 36V pair. I don't know what it does for speed. My Wrangler has a switch controled low range rated for 5mph & high rated to 10mph. With my worn steering approaching 10 mph is scary.
flagman1776
Postby Mr_fixit » 15 Nov 2016, 18:22
Different, and different. Pride pursuit uses a transaxle. Pride wrangler uses twin 1500 watt? motors. Pursuit uses an s drive 120 amp controller. Wrangler uses a Curtis 200 amp controller.
There were 2 versions of the Pride wrangler motors, one set was 24volt, I assume the older version, that would break. Have a broken one right now. The newer version, 36 volt, I assume , uses a different more robust gearing system that incorporates a bearing in the gearing or transmission. The older version used a pillow ? block bearing that was separate from the gearing.
Both 24volt or 36 volt Wrangler motors use the same controller.
Mr_fixit
Postby flagman1776 » 16 Nov 2016, 00:09
Yes I have theCurtis 200A controler. Here a arse view of my motors.
flagman1776
Postby Scollard » 22 Jun 2018, 06:04
So getting back to this. How can I make my 24V Pride Pursuit XL go faster.
1) Can the programming be tweaked?
2) Do I just update the controller and rewire my 24V pack to a 36V?
3) Do I have to do both?
4) Not worth the effort.
Scollard
Postby Burgerman » 22 Jun 2018, 06:18
Motors will work at 36V.
Battery can be reconfigured.
Controller must be one that can cope with and designed for a 12S pack or rather 3 lead acid batteries. A nominal 36V which means it must have a absolute max rating of about 48V
Users browsing this forum: shirley_hkg and 134 guests
