Burgerman wrote:http://www.ebay.co.uk/itm/UNI-T-UT203-Digital-Handheld-Clamp-Multimeter-Tester-Meter-DMM-CE-AC-DC-Volt-Amp-/351149081329?hash=item51c21dc2f1:g:oJcAAOSwxH1T40f4 20 includes delivery. Not super accurate and keeps needing re-zeroing by pushing a button, but 20 pounds inc delivery?
Burgerman wrote:True. You need to un-tuck it! And only ONE motor cable to each motor, not the pair. Easy enough, they are usually inside bits of pvc sleeve, and wires visible at the end. Or trim some PVC...
Burgerman wrote:You can measure anything on any chair. It just depends on how much effort you put in. If you expect it to work by magic that's not going to happen.
terry2 wrote:Burgerman wrote:You can measure anything on any chair. It just depends on how much effort you put in. If you expect it to work by magic that's not going to happen.
It would take more then magic. You do realise there is only 1 inch of space at the top of the battery where the two motor leads run?
To get to those leads you have to lower the battery bay. Take out both batteries and then and only then can you see them.
The shops have a special left for these chairs which you can't buy.
The Puma 40 is micro managed which nice for the looks and stuff but a pain for a person. I know..I got one.
Burgerman wrote:You can make a temporary extension loop. As I did here http://www.wheelchairdriver.com/gopro/motoramps.mp4
Burgerman wrote:I have that one. It can measure right down to the 1 or2 mA range accurately. Which is useful. But its limited to 100A. That may or may not be a problem for you.
Unless you use it for electronics or very small currents in the 2 to 30mA range you are better getting the https://www.amazon.com/Uni-T-UT210E-Cur ... =GTC+CM100 that shirley recommends. Much cheaper too.
Accuracy is more than we need
Users browsing this forum: No registered users and 96 guests
