hatam1996 wrote:hi
I made control board
And used Joystick Module
But it didn't work
Please give me the code I want it to work with the joystick model
CAN YOU GIVE ME sketch Modified code PLZ
You will find in this thread new versions of code that work better, if you post here you will have the most up to date information.
I have started working on it again, its summer here In Australia and I am getting ready for Squid season early in the new year.
I am now working on using the emulator to drive a Storm Arrow power chair with Brushless or 'GB' motors as Invacare calls them (Gearless Brushless)
The emulator works with the POWER MODULE , it replaces the JOYSTICK MODULE or in the case of woodys, used in parallel with a relay to switch between the joystick and the emulator.
To assist you better,
Please post pictures (as high res as possible) of the emulator you have built.
Please post screen captures of your data capture.
It is necessary when debugging this emulator, to supply a data capture of your board.
With out it there is no way to identify if its working.
Basic things to check are if the Shark Bus wires are plugged their corresponding Shark Bus HIGH, Shark Bus LOW.
Its not actually necessary to build up the emulator board to do the first phase of testing, the code can be loaded onto any Arduino Nano and snoop the output pin.
The emulator also relies on Libraries written by other people, changes to those can sometimes throw a spanner in the works.
If you start with supplying pictures of your build and data capture, we will be able to help you better.
As I am now actively working on this project again, I will post (On my webpage).
- Each version of the code that works, with out kinks.
- A video for each or links to past videos.
