Burgerman wrote:If you try to charge with a preset that ALLOWS a wide current range to be set you will be forced to use the middle 62khz one. It can be used from .1A to 40A.
If its an under 2 or 3A max preset for small cells only, it will give an error if you choose anything but the 31khz...
If its a high power preset, and current is set high, you will be able to use either the middle one or the 125khz one...
Its at its most efficient at 31khz. And its least efficient at the 125khs setting. But those are allowed only on low and high current settings/presets.
Burgerman wrote:Connect the PL8. Load the CCS program. Add the new preset or any changes you want. Then UPDATE the PL8.
I want to charge them as a monoblock via PL8.
Anyone have a preset? I am using balancer for charging only (or rather 14 balance boards for each cell)
sin85 wrote:sorry i will be clearer
i want to charge my pack as if it is a single 44.8V battery
Burgerman wrote:To do this you will need to use 2 SEPERATE and ISOLATED power supplies. Or smoke!!!
shirley_hkg wrote:sin85 wrote:sorry i will be clearer
You need a 0--60V CC / CV power supply ; not PL8 .
Could they be powered from one supply ?
