Furio wrote:Hi Irwin,
Thanks a lot. I followed your suggestion and the charger is working.
Glad to hear it.
Irving wrote:On many PC you won't find drivers for Com1 and Com2 because these are legacy hardware and are directly supported by the BIOS. Which is why it's always a good idea to avoid these Com ports. Com3 is the most likely to be the first usable port but is often allocated in legacy BIOS for serial mouse. Which is why it's often better to manually connect usb serial to ports 6 upwards. Yes, you can delete drivers as BM advocates.
http://www.usastore.revolectrix.com/Pro ... S/GT1200_2
how bad can this charger be for this price as a back up to the PL 8 ?
does anyone have one of them - it does come with software PC also -
Can you make the presets for this one also BM ?
Burgerman wrote:Potentially You COULD but you will need to first find out what type of battery it is. Then set the PL8 to 5mA, which is still a lot for a tiny battery. And then just run it for say 20 mins as a 1s aaa battery. And CLEAN the battery and the connections.
Be very careful though. They are not vented. So may explode. rap it in a rag... If it gets more than vaguely warm, stop... Of course they are not really meant to be rechargable. But they are a little. They are also about 1 pound for half a dozen on eBay.
Users browsing this forum: No registered users and 120 guests
