How many charges have you done in your Pack's life, and how many times has the PL 8 spotted something, made you aware of something, that you needed to rectify?
expresso wrote:i wont feel good without one that i can see the graphs - i have had about 3 or 4 times on 3 different packs - that i had to address -
i would not have know if i couldnt see the graphs - or another time - it was the dump load that got my attention but only because i can see the graphs at the same time
i noticed one cell dropping too fast right away - it was a connection issue - i had to resolve before starting to use the pack or install it -
but strangely - if i had never tested it with the dump load - i wouldnt have noticed - since the PL8 discharges slow - it didnt have an effect
once i discharged at 40A a hour - i noticed it - so its not 100% either - i now like to use the dump load after i build a pack to discharge some and make sure not any once cell is dropping too fast over the others - it could be a weaker cell also - depends if it keeps dropping or drops and then levels out - either way having the graphs to see it happening is needed - or else it would have been installed and used for who knows how long before it becomes a bigger issue - at some point down the line
my first pack - same thing after a year - i noticed something - turned out - cell was bad - headway - i changed that one cell and never touched it again - without the graphs - i wouldnt know and would have just kept using it -
this winter i also redid one of my ADD Ons - which had a connection issue on one Cell - i ended up stripping the Cell - no longer could use a screw on it - changed that one cell and fixed it back better with the connections -
without it - is like using a BMS - you never know what is going on - each time i build one i try to improve from the previous - either with wiring or connections - more careful to locktite the screw good - etc,
and still waiting for the PL8 - now its March - each month i call its the next month -
funkykeyboard wrote:PL 8 and regular use.
So once you have created your "perfect" battery pack, what is people's experience with the PL 8?
Okay I understand better now your earlier comments.expresso wrote:https://www.ebay.com/itm/24-Volt-1500-Watt-Divert-Dump-Load-Resistor-Bank-for-Wind-Turbine-Generators/390947911868?epid=2263228609&hash=item5b064fb8bc:g:sUYAAOSwHoNfWOfB
i have a small compact one - does 40A 24V - i wouldnt say stress - when we ride out chairs - it discharges much faster than the PL8 - so a dump load is somewhat how it reacts when you use the chair for real - most times the chair dosnt use 40A - sometimes it uses alot more - 120A and most times 15A
either way - if you connected one to your new pack - it will start to discharge it at a much faster rate - so you can see how the pack Cells react when under load for real -
if thats all you wanted to do - or if you wanted to discharge a 200ah pack - using the pl8 takes about 18 hours - if you wanted to do it faster - connect one in the chain and still use the pl8 to monitor the volts - so you can stop it before they go too low and damage the cells
just a way to discharge faster - that was my main reason for getting one - and i realized its good to use to check the pack - since its closer to how it would react under real life using the chair outside -
Re: Hi! John
Sent: Wed Jan 13, 2021 3:15 pm
To: elryko1992
Does it still do this download download/file.php?id=14754&mode=view
Re: Hi! John
Sent: Wed Jan 13, 2021 4:53 pm
To: elryko1992
You have a bad connection on a terminal.
Re: Hi! John
Sent: Wed Feb 10, 2021 10:46 am
To: elryko1992
You should have installed them with RED LOCTITE and not overtighten them. Or the nuts.
You should use abrasive paper on the surfaces before connection. To remove all oxides. You should use a stainless nyloc nut and a stainless flat washer. I would not have used M7. I would have helicoiled every cell.
That graph told me you had bad connection somewhere.
Please post this info on the forum.
Re: Hi! John
Sent: Wed Feb 10, 2021 10:29 am
To: Burgerman
Hi! I change all the screw to my cells, i found 3 hole broken and i make it again and put M7 screw, very nasty... but i did. i will charge this days to see the graph. Thanks BM. i put this 2cm. https://www.ebay.com/itm/M6-Stainless-S ... 1195.m1851
Wow! That's like scary psychic shit.Burgerman wrote:I diagnosed which call, which connection, based on what I saw on that graph very easily. When he took it apart he found exctly what the PL8 suggested. Diagnosed in the UK based on his graph in rumania. I look at my charge graphs on every single charge. Mostly they show no problems. Except maybe say cell 5 has higher self discharge, or cell 8 is higher resistance but not enough to worry about yet. Or that I should tweak the termination current a little based on what I see.
expresso wrote:i think most of us - at some point become familiar with distant range - and battery life - that you just know more or less - how many miles you can do - i save my charge graphs but i dont add in the details of that days range - with my chairs - i just know give or take
i figure 90ah - pack - good for 30 miles safely - 200ah pack 50 miles - 60 miles easy - all depends - give it a good year of using a new chair with lithium and you know - but good idea to save on a spread sheet if you put the time in to enter the info.
or at least put the info. on the graphs when you charge and save them - date and distance traveled- plus how much battery used -
Users browsing this forum: Burgerman, DirtinLa, Google [Bot], Heygnow, Jay_x, Roadrunner, shirley_hkg, Tetralytic, Yennek and 49 guests
