Ok after this is done - i am not watching it - but its still going - not sure where its at now - not sitting in front of it - i will change the preset after to 10A charge rate - 3.550v and 150mAh Term.
10A? It will cut off the charger as soon as it ends CC stage. No balance, and 95% charged.
what can i tell you - this is how its working
If that charger turn off, after CC stage alone its *not* working as intended.
others that have this chair etc, just use there charger and not worry about it - they seem to be fine - or at least i dont hear about anything Neg. - but they dont know better so whos to say - i check it later and report back -
Maybe others dont stop after CC stage alone. I am still not convinced yours does. You should wait a long time see if it begins charging again. If not, then it is not doing as intended.
OR Can it be that they are balanced enough - if the pack was built well with close matching Cells etc, ? since i have been using the chair and recharging etc, - they may not need much balancing at this moment ?
Even if balance was perfect and it wont be, there is still no CV STAGE! It just cuts power. So it will be about 90 to 95% charged, not balanced.
or there supplied charger is a match to there BMS - maybe they need to working together to get the best charge out of it ?
You monitored that. CV non existent so no balance and incomplete charge. The BMS expects a constant voltage. It can then turn back on once its dropped the high cells to a lower voltage and continue. Thats just how charging and BMS work. But that charger had stopped. As things stand it appears that you have no CV stage at all and thats where balancing happens. It is chopping off the charger as soon as it sees a high cell. It might work for a long time that way. But its wrong regardless. Theres no Battery "magic" happening.
