Scooterman wrote:How many supply volts is PL8 happiest at?
Also I noticed that amps on shirley's psu is a bit higher than charge current. But reading what you just said I twigged that CV is higher than PSU V so to deliver equivalent power (reality slightly more cos of losses (heat, etc)) then PSU amps have to rise to balance power (amps/volts) seesaw.
Learning all the time
Scooterman wrote:steves1977uk wrote:I leave my PSU set to 30v as this is less stressful for the PL8 as less Amps are drawn. But 24v-30v is recommended SM
That makes sense Steve. I will up my PSU volts too
Burgerman wrote:Volts x Amps = watts Output.
Because Volts x Amps + 10% Approx losses = Watts input.
Remember though that the charger is both a buck and boost inverter. If you begin charging as a buck (voltage lowering) converter, and as you start to charge the battery voltage rises, it then has to stop being a buck, and switch over to boost. As it does, the battery voltage drops... So now it has to swap back. Rinse and repeat and maybe error...
This was while charging a few Lipo cells I had salvaged from a laptop battery.
Burgerman wrote:Probably. Never saw one.
shirley_hkg wrote: Do I still need the balance leads if doing just 1 cell ?
I am having a problem with running PL8 charger. I had formatted and reinstalled windows 7 on laptop with all recommended updates. Then I installed the CCS , but the FUIM3 driver had to be installed manually as windows did not recognise it.
ex-Gooserider wrote:shirley_hkg wrote: Do I still need the balance leads if doing just 1 cell ?
As BM said, no you don't need the balance wires if doing one cell (or a bunch in parallel)...
I wouldn't advise it unless the cell was very small, but you can also charge via the balance wires alone, and not use the main power leads - but charge current is very low (max under 500mA if I remember correctly) if doing this, so only practical for really tiny batteries....
Furio wrote:Hi BM,
#It can be any com port windows decides. But I have no idea what your computer is doing. Its a hardware issue. Your win 7 laptop may have a faulty USB or the USB is configured incorrectly or something.
What does it show in device manager when you plug in the PL8?#
Now ,when I open the CCS software, windows hangs.
When the FUIM3 is plugged in, there is no change on the COM1, which is the FTDI USB - serial port.
I do not know what else to do.
Users browsing this forum: FrontierNZ, mentado020477 and 23 guests
