The drive gear on the wheel is an inch or so less diameter than the tire. I'm just wondering how the tint gets sucked in there... and what I can do about it.
flagman1776 wrote:What do you think of my oiling the roller bearings?
flagman1776 wrote:Thanks ex-G!
I think I'm a long way from needing to replace the bearings but I did take a good look while I had it apart. I measured the shaft .38"D because I'm going to turn up a dummy shaft (with a tapered nose) to improve reassembly. The bearings were all bright, so they may be stainless already but they are small. I didn't see any numbers but that doesn't mean they are not there somewhere.
I have removed the excess velcro where I think the fibers came from but lint & dust is everywhere... unavoidable.
Williamclark77 wrote:flagman1776 wrote:What do you think of my oiling the roller bearings?
A drop of oil inside is good. Mainly for rust/corrosion purposes moreso than a lube. Those bearings are run at such low speeds and light loads that they'll last virtually forever from normal wear. It's the dirt, hair, etc that get in and ruin them. No way to really avoid it but do as you're doing occasionally.
Don't ever use any of the modern super slick moly or teflon type oils in ball bearings unless it specifically calls for it. They're too slick. The balls will literally slide in the guides instead of roll and get flat spots.
Users browsing this forum: shirley_hkg and 98 guests
