expresso wrote:why even bother with Fuses on the Main pack in the chair - why not just use a Breaker - wouldnt that be best ?- if it ever trips - you just reset it -
and not worry about fuses to change etc, i mean if you solder a fuse - its a pain to change it - i never had one blow or trip on any chair so far - so it shouldnt but in the event it did - would be easier with a breaker -
rustyjames wrote:One of my chairs has a set of AGM group 24 batteries that are probably about 4 years old now. When I fully charge them and let them sit overnight the voltage is 25 volts. Would it be ok to connect the add on pack? I don't want to hurt my new investment.
expresso wrote:Dan - your going to make a 30ah Pack - look back from Page one here - i have pictures - you can follow them - it will show you how to arrange the Cells - attach the balance wires etc, -
when you say a BIT - what does that mean - Did you charge each Cell with the PL 8 Full and left them ALONE for a MONTH or TWO ? at least a MONTH is fine - before you continue ?
Dan wrote:expresso wrote:Dan - your going to make a 30ah Pack - look back from Page one here - i have pictures - you can follow them - it will show you how to arrange the Cells - attach the balance wires etc, -
Yes I had fully charged each cell when I got them. They have now been sitting for a few weeks. I'm charging them back up. I numbered each cell when I first charged them.
I'm looking for the capacity returned to each cell? This one is 179mAh.
Dan wrote:It was a few weeks. Just checked the date they were charged. It was early July so they haven been sitting about eight weeks.
Highest returned so far is 275mAh, the lowest is 105mAh.
Dan wrote:"you are making a 30ah pack - 16 15ah Cells"
Yes, I hope so. I bought 18 15AH cells in July.
Burgerman wrote:Build a pack, make each parallel group have approx equal discharge.
