hank wrote:
Is there any way to disable freewheel levers on brushless motors
as one of mine has broke off level with casing
they are very brittle hollow plastic.
Could they be disabled with wiring or will have to remove lever arm part
inside casings first.
NO, I mean you should find a way to prevent the plastic part from rotating (change to free wheel position by itself).
It is supposed to be held in place with a spring load linkage , but it is broken now .
