Part of my Invacare chair project is making a spacer and extra caster mount in order to increase the distance between the front casters, so that I have room for the center foot-plate when I move the seating back...
I got an extra frame that I cut up in order to make the caster mounts, and I'm trying to strip the paint off so that I can powder coat the parts once I have all the machining on them done... (We have powder coating equipment here at the Asylum, so no sending it out...)
However I am having an amazingly difficult time getting the old paint off - I have tried:
1. A "green" citrus based stripper... Got some paint off, but left a lot... It also gave me some nasty chemical burns on my hands (hint - surplus nitrile gloves from the cath kits are NOT adequate... )
2. A stronger traditional stripper - Savogran "Strypeze" - a couple of times - got more off, but still didn't do very well...
3. Propane torch - no visible effect...
4. Baking in toaster oven for an hour at it's highest setting (supposedly 450*F) - no visible effect...
So I did some searching and found lots of suggestions for "Aircraft Remover" - supposedly the "nuclear option" paint stripper - seriously nasty stuff, the MSDS is 12 pages explaining all the nasty things it could do to you - the hazard diamond thing that summarizes was all red except it isn't very flammable...
So I got a can of that, it was the aerosol version rather than the brush on, which may have been a mistake, but.... Same deal, it got some of the remaining paint off, but didn't do a lot better than the first two overall... I'm seriously underwhelmed
So any ideas about what Invacare used for paint on their chairs? It isn't powder-coat, as it has a primer layer under it. The stuff that did come off did so with scraping in some cases, and other areas just peeled, but I didn't get the paint 'bubbling' up like I've experienced with other times I've stripped paint...
Even more importantly, ideas about how to get it OFF? I'd rather not do mechanical removal as I don't want to damage the metal, (and our sand blaster isn't accessible) there are also some T-slots and other areas that really only can be reached with chemicals...
