woodygb wrote:Have you checked the motor brushes?
Burgerman wrote:The dreaded crimp joint strikes again...
SOLDER...
woodygb wrote:https://www.ebay.co.uk/itm/electric-wheelchair-joystick-Control-D50422-01/332421966234?hash=item4d65e4a99a:g:XawAAOSw8DJZ7Ris
https://www.ebay.co.uk/itm/Electric-Whe ... SwzilZ1hfT
woodygb wrote:Buying a 2nd VSi would seem sensible..... I have in the past picked one up on Ebay for under £20.
ex-Gooserider wrote:I'd agree with the value of having spare controllers, (as well as Joysticks, motors, etc.) that can be swapped out.... However even if the wiring LOOKS good, regard it with a great deal of suspicion... Even the soldered connections can fail, they just do so differently and can be harder to detect when they do.... Soldered joints particularly, but ANY wire can fail internally under the insulation such that the wire looks perfect, but is intermittent...
Look for any signs of kinks, bulges, thin spots, or any other sort of imperfection in the wires, including very sharp bends. Pay special attention to the areas right next to connectors, and any areas that get flexed a lot (i.e. where the harness goes between moving bits...)
Give connections a good tug to make sure they are still solidly attached to the wires.
Ideally put a swing meter or continuity light across both ends of each wire and watch for any signs of flickering or changes in resistance while shaking the crap out of the wire...
Intermittents are about the worst sort of fault to try and find, basically if boils down to detective work, and patient going through every little bit... (Might be easier to replace the wiring...)
woodygb wrote:http://www.nithsdale-wheelchairs.com/electromagnetic-brakes.html
You can drive with them in freewheel as long as you shunt the microswitch, and you can even drive with the brakes removed from the motors. However, if you stop on a slope, the chair will drift down hill. Without the brake clickety-clack the chair gets a lot quieter, and some people prefer to get rid of them and drive in stealth mode.
woodygb wrote:https://support.pgdt.com/Online-Diagnostics/Flash-Code-List/VSI-Flash-Code
woodygb wrote:There should be no problem.... other than the motor connections.... in swapping over the control systems.
Burgerman wrote:Crimps are an endless source of problems. Been keeping auto electricians and boat and wheelchair tech guys in work for decades.
Solder them...
Users browsing this forum: Mr.Math, shirley_hkg and 146 guests
