alfiepink wrote:If it was me i would use impact wrench. Can you use some penetrating oil ?
From alfie
expresso wrote:Do wheel bolts have to have Tread lock on them ? i recall when my tech replaced mines - there wasnt any on the bolts to hold the wheel to the motors - and he didnt add them either - i asked him - he said wasnt needed - - i never gave it any though after that and its been fine - the only small amount of blue tread lock was found on the Rims - two part rims - i have about 8 allen screws going around the rim which did have some on there - not sure it was re added since the bike shop did the work - i asked them to add it and supplied it at the time -
but the bolts themselves - 4 going to the motors - i know didnt have them - - have to be strong to remove them and re tighten for sure -
chair was quickie 646se - i see those are smaller allen bolts - not the same as used on mines - that could be the difference and maybe there is thread lock there -
We are sorry! / Es tut uns leid!
Page not found / Seite nicht gefunden
hank wrote:Can you get access to a (impact wrench)
Or get a socket type Allen bit then knock
It on wheel screws first to shock the screws
Failing that get a long tube over bar for
More leverage.
rover220 wrote:https://www.ffx.co.uk/tools/product/Bosch-Gds-18-V-Liht-3165140726542-18V-High-Torque-Impact-Wrench-2-X-4.0Ah-Li-Ion
Burgerman wrote:That takes all the effort out of it! Torque free. Even a weakling can use those.
flagman1776 wrote:The outter 4 bolts have 2 functions... the wheel itsellf is a split rim... there are 2 halves. Have you removed the valve stem & deflated the tube otherwise the air pressure puts pressure on these bolts. The bolts also go through a wheel hub flange either threaded into it or with nuts on the inside.
Been there, done that...
woodygb wrote:It would APPEAR that the wheel rim is split on the outer edge and the wheel rim assembly is attached ... by the 4 bolts / screws... to a keyed carrier on the motor shaft.
I have seen a similar combo on mobility scooters and the 4 bolts/screws had nuts that where retained in recesses on the reverse side of the main drive coupling.
Users browsing this forum: DrewDigital, woodygb and 48 guests
